leather seat issues factory installed
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dragon168, Feb 14, 2012.
  1. dragon168
    dragon168 Junior Member
    26
    ca
    only have 20K less than 2 y.o. Prius i have several issues with my leather seat. toyota replaced the back leather seat but it look so brittle. now my front driver side it has a "rip" on the side. anyone have similiar concern about the leather quality of toyota? thanks!
  2. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    What trim do you have? It could be port-installed depending on the trim, in which case it's not a quality control issue with factory-installed leather.
  3. dragon168
    26
    ca
    gray. so if it is a factory-installed leather, im out of luck? it is a pain dealing with the toyota dictrict service parts manager.
  4. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Gray is a color, not a trim. What trim do you have? Two (II), Three (III), Four (IV) or Five (V)?
  5. dragon168
    26
    ca
    oops my bad LOL! ok i'm assuming i have IV will meet the the disctrict guy tomorrow.
  6. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    So you're not even sure if you have factory-installed leather? There have been a few posts regarding quality control issues with port-installed leather found in the lower trims.
  7. dragon168
    26
    ca
    it is factory installed, im 100% sure. toyota replaced the back seat ,but the replacement is equally bad. i just don't know how to address the issue, i dealt with district service parts manager already and it was like you are in court proving your case.
  8. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    If you're not sure what trim you have and can only assume it's a IV, then you can't be sure it's factory installed.
  9. dragon168
    26
    ca
    as i indicated earlier i am 100% sure it is factory installed not DEALER installed. i checked it with TOYOTA and yes it is showing factory installed!
  10. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Fine. Keep in mind that dealer-installed isn't the same as port-installed.
  11. vet430
    vet430 Junior Member
    Illinois
    The issue is , you bought it from toyota with installed leather, no mater who installed it. It came new with the car and they should stand behind it 100 percent period. End of story. Climb the latter until you find somebody that will take responsibility.
    I have worked for Honda, Volvo and Infinity and never an issue with satisfying the customer.
    ~Jim
  12. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    I don't disagree with that, but the point is there have been quality control issues with port-installed leather that are not seen with factory-installed leather (judging from a number of posts here) so that's an important distinction to make. The OP did ask if anyone had similar concern about leather quality/fitment.
  13. Mr.Electric
    Mr.Electric Member
    287
    102
    San Francisco
    The leather on my Prius IV seems to be tearing at a few seams , shrinking to be too tight in several places.
    I'm not sure how to check if it's port installed.
  14. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Port or Dealer installed leather is usually 3/36,000 miles, depending on the Regional or local Dealer policy and applies to Level II or III. Level IV and V came with factory Leather. Factory Leather is covered under normal warranty. You do not list your vehicle, but based on your date of membership as reference to purchase date, those are the rules. You will have to deal with legal definitions of normal wear though.
  15. VSUIRP
    VSUIRP Junior Member
    25
    Tampa Bay
    2013 Chevy Volt
    When I had my 2010 the Driver's side "leather" seat had what looked like a tear, but it was just the material had pulled away from the hooks that attach it. The dealer 'fixed it, but it happened again, so they got me a new seat. It cost me nothing (it was covered under warrantee) but the price listed was almost a thousand dollars! By the way it was factory installed and the stuff is not leather. I don't have the prius anymore, I now own a Volt, a really fantastic car.
  16. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    If you had a 2010 IV or V, then it was factory-installed leather. Not sure which model year replaced the leather with Softex, but Softex wasn't used in 2010.
  17. Mr.Electric
    Mr.Electric Member
    287
    102
    San Francisco
    It's fake leather on my 2010 IV
  18. RRxing
    2,520
    1,791
    NEPA
    Then something is amiss.
  19. danvee
    danvee Blizzard Brigadier
    326
    53
    38
    New Jersey
    The description generally states 'leather seating surfaces', so, only the center insets are actually leather. The balance is 'pleather'.
  20. Mr.Electric
    Mr.Electric Member
    287
    102
    San Francisco
    Yes the edges are the parts I examined.
