Leaving for a month
Discussion in 'Gen 2 Prius Main Forum' started by wruu, Oct 15, 2019.
  1. wruu
    wruu New Member
    United States
    so I'm leaving a month tomorrow and can't get a trickle charger because I live in an apartment complex with no outlet. My previous trip, I was gone for a month and the battery just died on me and I had to get another one. I'm trying to avoid that, so what would be my best options? Would it be a bad idea to just remove the 12 volt? I don't have anyone to drive my car.
  2. PriusCamper
    PriusCamper Senior Member
    12,048
    4,892
    Pacific Northwest, USA
    Yes, pull the 12v and bring it inside and soon as you get home after a month, start charging it... Then by the time you're ready to use the car it'll have a nice strong charge on it.
    51,140
    just unhook the negative. you will need a 12v source to pop the hatch when you get back, unless you don't mind climbing in.
    make sure your mechanical key works.
  4. richmke
    richmke Member
    73
    48
    Milwaukee, WI
    If you park outside, you could try a solar charger. This one will also condition the 12v battery.
    Battery Tender 12V, 270mA, 5W Solar Battery Charger
    Did you turn off the Smart Key (button under the steering wheel)? That draws a lot of power.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Deactivate the SKS using the button below the steering wheel. That alone should allow a good battery to last over a month.
  6. cthindi
    cthindi Member
    177
    85
    Connecticut
    With a car over 10 year old, I would be more concerned about HV battery than the 12 V one. After a gap of one month, that needs to have enough power to crank the engine.
    Please make sure it is fully charged when you leave it. You can force charge the battery by using left foot on Brake and then using right foot on gas and putting the car in Drive to force charge the battery.
  7. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    Solar chargers hooked straight to the 12v battery or jump points. Very low rate so no fear of overcharging.
  8. richmke
    richmke Member
    73
    48
    Milwaukee, WI
    With a solar panel inside the car, don't use the 12v sockets. They are not on when the car is not on.
    The OBDII port is always live, so that is an easy to access point for temporary use.
  9. meeder
    meeder Active Member
    239
    162
    Doesburg, The Netherlands
    Good tip! I will be doing that before going on vacation. That way the battery is fully charged when leaving it unattended for three weeks.
  10. Mendel Leisk
    40,574
    What mostly drains the battery is being connected to the car: the slow but inexorable discharge imposed by the car's background needs. Any of the above mentioned battery disconnection methods would be effective; either @bisco's disconnect the neg cable, or @PriusCamper 's bring it up to your apartment.
    I'd suggest to get yourself a decent smart charger too. Our car's often idle for multiple days, then we maybe do just a short shopping trip. I use a CTEK 4.3 with a quick-connect, pretty much 'round the clock: keeps the battery like new.
  11. meeder
    239
    162
    With normale ICE cars I never had a problem with the 12V battery with the car standing 3 or 4 weeks. The 12V batteries in our hybrids are of course quite a bit smaller. Mine has a 45Ah battery whilst our ICE car has a 75Ah battery.
