Leaving traction battery SOC low overnight
Discussion in 'Gen 3 Prius Main Forum' started by hummusdude, Feb 3, 2020.
  1. hummusdude
    hummusdude New Member
    Portland, OR
    The particulars of my geography make it easy for me to drive the last few miles home at low speed in EV mode. Recently, I've been in the habit of doing this and it uses up all of the available battery down to 2 bars, right before the car starts the motor automatically to charge the traction battery. In the morning, the motor will run for 10 minutes or so regardless of the charge on the traction battery, so it seems like a more efficient use of that motor time. I'm wondering if this is putting excessive stress on the traction battery.
  2. bettergolf
    bettergolf Active Member
    424
    339
    Sanford NC
    I wouldn't think so the battery is programmed to protect itself. The engine runs to warm up so I think it's efficient to have it charging if it's going to run anyway.
    Johnny Cakes and Mendel Leisk like this.
    49,429
  4. hummusdude
    Portland, OR
    That's my assumption as well. Thanks for your 2 cents!
  5. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Thought you have about 45 secs before EV kicks out and cannot drive no farther than 1.5 miles without ICE before auto regen kicks in.
  6. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    This is abnormal.
  7. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Might have to something to do with this:
  8. hummusdude
    Portland, OR
    Thanks Grit but not quite sure what you mean.
  9. hummusdude
    Portland, OR
    Are you saying it's abnormal for the ICE to run a few minutes when first started? My 2012 V has always done that so I figured it was normal...to warm up the ICE.
  10. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    My hv bat gets driven down to 40 to 41% SOC every night and cold soak start up, ICE is not on more than 3 minutes during winters.
  11. fotomoto
    5,602
    3,778
    So. Texas
    OP might have a 10 minute leg every morning before the first stop/opportunity for ICE shutdown.
  12. hummusdude
    Portland, OR
    Sorry...OP?
  13. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    OP = Original Poster
    Raytheeagle likes this.
  14. Threej
    Threej Member
    99
    99
    Portland, OR
    Is this winter on Venus? Sure, I can get in the engine to shut off *at a complete stop* after 3 minutes. But shut off at 30 mph? That takes 10 minutes (maybe faster if I had to grind it up a hill or accelerate to freeway speed first) .
  15. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    211
    used to be "Glacial" Maine and now FL
    "Geography" meaning slight downhill to get some brake regen during the last few miles? Extends EV capability?
  16. hummusdude
    Portland, OR
    More like mostly flat and 30 mph zones or less.
