LED Accent Lights
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Tideland Prius, Sep 13, 2006.
  1. Tideland Prius
    16,125
    Alright, so bmcgraw (hope I got the name right) has blue neon tubes on his Prius (search for it, it's pretty cool... unless his pictures got swiped from the database).
    The challenge now is, can anyone help me with these?
    http://www.clublexus.com/gallery/showgallery.php?cat=3746
    Specifically, the installation part. The guy mentioned something about an ignition wire on his 95 ES300 (the pics are a 01 RX300 and are used as representation).
    Basically, I prefer to have the LED spots than a neon tube. bmcgraw suggested using a 451M solenoid relay so that the lights will work in conjunction with the interior lights (on when they're on and off when they're off).
    Has anyone done something similar? How is the difficulty level?
    TIA
  2. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Rather than the interior lights, i think i'd rather tap the exterior lights, so you don't have to drive around with an interior light on all the time, which could get annoying at night (the only real time you want the lights on, anyways). I would imagine that finding the correct wire wouldn't be too difficult if you've got a multimeter handy. just get the wires coming out of the stalk on the steering wheel and move them into different positions, see what equates to what. From there on out, it would just be a fairly simple matter of running the wires.
  3. Tideland Prius
    16,125
    Hmm, actually I want it to come on when I approach the car and go off when the interior lights do. The reason is that up here, it's illegal to have underbody lighting when the car is in motion.
  4. Tideland Prius
    16,125
    Hmm, looked under the car and there doesn't seem to be many good mounting points. How did those of you with neon tubes do it?
  5. TheForce
    3,461
    537
    Wheelersburg, Ohio
    <div class='quotetop'>QUOTE(Tideland Prius @ Sep 28 2006, 08:28 PM) [snapback]325331[/snapback]</div>
    I would also like to know how they are installed. I would also like to see some puctures. I've been thinking about adding some red neon to mine but havnt decided yet.
  6. Tideland Prius
    16,125
    assuming the pics didn't disappear with the crash, BcMcgraw has some in one of the threads. He has blue neons that are linked to the dome light.
  7. TheForce
    3,461
    537
    Wheelersburg, Ohio
    <div class='quotetop'>QUOTE(Tideland Prius @ Sep 29 2006, 01:59 AM) [snapback]325454[/snapback]</div>
    I found the thread but the pics are gone. :(
  8. Tideland Prius
    16,125
    I checked my file. I don't have them saved, sorry. Perhaps PM him?
  9. Frank Hudon
    Frank Hudon Senior Member
    4,147
    there is probably room for a short neon just in front of the plastic belly pan on the passanger side I'd say 8" max long and 3/4" in diamater. What ever that works out to in those Trudeau inches. Way easy on the Classic but it doesn't see you coming in the dark the way the SKS does.
  10. Tideland Prius
    16,125
    I know neons will work since BcMcGraw added them to his Tideland but these LED lights are slightly different.
  11. Frank Hudon
    4,147
    <div class='quotetop'>QUOTE(Tideland Prius @ Sep 30 2006, 01:09 PM) [snapback]326154[/snapback]</div>
    drop the belly pan figure out how many on each side go to R+P or Active and buy the LED's drill the holes to fit them and figure out what the current draw is on the whole bunch calculate the resistor required, run the wiring and glue the whole wire assy and the LED's in with RTV Silicone and then hook the resistor into the wire from the interior light circuit and thru the firewall in a grommet down to the wire harness off the belly pan. A sunday worth of work in your garage.
  12. Tideland Prius
    16,125
    ok, you lost me at R+P.... I think I know how to install (haven't bought the lights). It's just.. WHERE cause the car's too low and if I install it near the edge, I'm bound to damage the lights if the car bottoms out.
  13. kenmce
    kenmce High Voltage Member
    1,527
    502
    NY
    I've added a variety of LEDs to my Pri, but not your exact setup. I would break the project down into parts:
    What effect do you want from the lighting? Dots of light? patches? A glowing cloud? Colors? You'll need to round up LEDs that are appropriate to the job. I would get ones that are already set up to run on 12 V DC and that are already waterproof.
    You need to decide where to tap in for power. Do you have any existing lights that already behave exactly as you want the undercar lights to behave? If so, run a line to them for your positive power connection. Consider giving the new lights their own fuse if practical. Because you are going LED you could probably skip the relay. You are not (well I think you're not) drawing that much power. If you can tap in to a fuse under the hood that would be good because you won't have to run a wire into the inside of the car.
    You have the mechanical problem of fastening stuff onto the bottom of your car. I can't give you any details because I have a Classic, you have one of the new Pri. I don't even know if you have plastic or metal. Your basic options are:
    Screw into
    Glue onto
    Hang from
    Magnet on
    Drilled down from above, just the nose of the light protuding. (Hardest to do, ruggedest result)
    You will want the components to be protected as much as possible against water, salt, ice, scrapes, and debris. Look for recesses, existing fasteners you can use, existing structures you can run cable ties around. The electrical wires will also need to be be very well secured.
    Once you answer all these questions, you basically have your project.
  14. Tideland Prius
    16,125
    Hey Ken,
    thanks for the response.
    The thing is, is that the lights are designed for the exterior of the car so I'm sure it's waterproof and such. However, it'd be nice to have some plastic shield since it's easier to clean the plastic than each individual unit (10 in all, 5 a side). Also, it's mounted via double sided tape (which is quite strong considering the one I have for the footwell lighting from Toyota Japan is strong) but I won't feel confident so screwing as a backup seems likely.
    The biggest problem is that I looked under the car and it seems like a neon tube would fit better than the lights I intend to add because neon tubes give a flood light so it doesn't really matter where it's mounted cause there'll be light underneath the car regardless. With the accent lights, I'm looking at 5 patches of light per side so they HAVE to be aligned properly and there doesn't seem to be a place under the car close to the edge where I can have all 5 properly mounted and aligned. :(
  15. kenmce
    1,527
    502
    NY
    You're welcome.
    >The lights are designed for the exterior of the car so I'm sure it's waterproof and such.
    Excellent.
    >However, it'd be nice to have some plastic shield since it's easier to clean the plastic than each individual >unit (10 in all, 5 a side). Also, it's mounted via double sided tape (which is quite strong considering the one I >have for the footwell lighting from Toyota Japan is strong)
    If it's designed for there it should work. Clean off the spots where the tape will go as best as you can, so you get a good bond. I have LEDs glued to the exterior of my car with silicone. It won't take mechanical stress (scraping) but otherwise is holding up nicely.
    The main concern with screws is to find spots where there isn't anything important above where you want to drill the hole. For me this involves a lot of climbing back and forth, locating reference marks that show from both sides and measuring out from them. Take a couple aspirin before you start. I would suggest that just before you put in your sheet metal screw you take a tube of silicone sealant and squirt as much into the screw hole as will go. Some will ooze back out when the screw goes in. Use this to seal over and around the head of the screw. What you are doing is trying to add a moisture barrier that will have a chance of lasting the life of the car, and have a chance of working even if the screw is removed. Use galvanized or zinc plated sheet metal screws. Stainless would be better, but I don't think they exist.
    >The biggest problem is that I looked under the car and it seems like a neon tube would fit better than the >lights I intend to add because neon tubes give a flood light so it doesn't really matter where it's mounted >cause there'll be light underneath the car regardless.
    You can buy LEDs in a long tube. Reference:
    http://search.ebay.com/search/search.dll?s...earch&fgtp=
    If the link gives you trouble go to http://www.ebay.com/ and enter the search string "led undercar light"
    >With the accent lights, I'm looking at 5 patches of light per side so they HAVE to be aligned properly and >there doesn't seem to be a place under the car close to the edge where I can have all 5 properly mounted >and aligned. :(
    I understand. I noticed that the lights in your link were spaced only between the front and rear wheels of the SUV and with a uniform spacing. Looked OK on him, but you don't have to do that. What happens if you go all the way out to the edge? Would under the doors perhaps work? Around the wheel wells? Backlighting the tires? Towards the front and rear bumpers? If they are symetric from front to rear you can change around the number and spacing and still look good.
    I'm getting tempted to go crawl under a new Pri that has taken to parking in my neighborhood lately. Do you think the owner'd understand? (G)
  16. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    <div class='quotetop'>QUOTE(kenmce @ Oct 14 2006, 10:35 AM) [snapback]332707[/snapback]</div>
    I'd bet he would if you asked him. :)
  17. Tideland Prius
    16,125
    <div class='quotetop'>QUOTE(kenmce @ Oct 14 2006, 07:35 AM) [snapback]332707[/snapback]</div>
    The problem with under the doors is that half of the car (cant' remember which half - fore or aft) is flat and the other isn't (I believe there's a crevice of some sort) so some of the lights will be seen from the side and the other lights will be hidden from view because they're further "up" and out of sight when looking from the side. I think it will make more sense if you look under your neighbour's Prius. heh.
  18. BMcGraw
    BMcGraw Member
    230
    Southern California
    [attachmentid=5336]Sorry to hear "my" neon pix disappeared. I'll repost them... how's that. :D
    As not having a place to mount the neon or led's for that matter the easiest solution was to remove the plastic panels beneath the left and right sides of the car. They're just screwed on with approximately 8-10 screws/bolts on each side. That exposes a void from front to rear appoximately 3" wide like most other cars have. I'm sure there's a small hit to MPG due to aerodynamic influences but I thought it would be worth it.
    As far as the hookup goes I suggest contacting someone at your nearest Circuit City. That's what I did. It's all under warranty and came be removed without evidence of its installation.
    Hope that helps.
  19. Tideland Prius
    16,125
    Yeah, I remember asking you about it when you added yours on. I'll remember to save the pictures this time lest we lose it in the next site crash.
    Do I still need that 451M solenoid relay you speak of? From what I heard over at Club Lexus, I just have to tap the wire leading to the ignition switch light.
  20. Cheap!
    Cheap! New Member
    1,157
    <div class='quotetop'>QUOTE(BMcGraw @ Oct 15 2006, 08:11 PM) [snapback]333214[/snapback]</div>
    I like it! :D
    Knowing that everything is not for everybody....I don't want all of them for me, but I have to get some for the front grill.
    Thanks
    Clear Plastic is your answer. It would protect the bulbs and it would be easy to clean too.
