LED Bar Third Brake Light
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Lladnyk, Jan 3, 2019.
  1. Lladnyk
    Lladnyk Member
    48
    57
    So I ordered a smoked third brake light assembly from iJDMTOY that plugs directly into the stock plug from the old assembly, except there is additional red wire on the smoked assembly that is supposed to be used to power an LED bar as a running light. I really like the look of the bar, however, I don't want to use it as a running light, but rather have it light up with the rest of the LEDs as I press on the brake. How could I connect the extra red wire to achieve this?
    I also took some photos of the stock plug, it has a blue wire and a white wire with a black stripe. It's hard to see because the plug only comes out of the spoiler by an inch or so.
  2. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    It looks like you have exactly two wires to choose from. Since they both carry the circuit when the brakes go on,I'm going to guess that tapping into either wire will do the job for you. AmIright?
    James Powers likes this.
  3. gliderman
    gliderman Active Member
    751
    225
    "There is no modification required, simply unbolt the original 3rd brake lamp and directly replace back with this JDM one. The Toyota JDM 3rd brake also comes with an optional wire which you can leave it alone, or you can also choose to connect it to your stock taillamp's positive and let your JDM 3rd brake function as rear fog light or tail running light."
    HeadOfJarg likes this.
  4. Lladnyk
    Lladnyk Member
    48
    57
    That's what I was wondering. Would it matter which wire I tapped into?
  5. Lladnyk
    Lladnyk Member
    48
    57
    The lights came in today, plugging them in directly just lights up the individual LEDs not the bar. I tried stripping some of the red wire then sticking it in the stock plug before plugging it in and neither side worked. My electrical knowledge is very limited if it wasn’t obvious already. Anyone know how I can connect this wire to be a brake light and NOT a running light?
  6. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    Best bet is to go and get some wire taps and just attach to the wires.
  7. RightOnTime
    RightOnTime Senior Member
    789
    1,657
    183
    Kidnapped in OC, CA
    Is there a Red and Black wire together?
  8. Lladnyk
    Lladnyk Member
    48
    57
    No, the stock plug has a blue wire and a white wire with a black stripe. The new tail lamp has a direct fit plug plus an extra red wire. No black wires.
  9. outtabounds
    outtabounds Junior Member
    31
    Metairie, LA
    Does it fit 2nd gen?
