led foot well light question...
Discussion in 'Gen 3 Prius Audio and Electronics' started by N2MPG, May 5, 2014.
  1. N2MPG
    N2MPG Junior Member
    30
    Radford Va
    OK, I've searched and found things similar but I'm looking for which wire in the kickpanels on the driver or passenger footwells do what.
    - I'm looking to see if one of those goes to the dome?
    - is there anyway to tap into the power location where the factory footwell illumination would have gone?
    Thanks in advance
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    The foot well lights are independent from the dome light. They are only on at night when the parking lights are on. When in park, the foot well lights are on full brightness. Once u go into drive, they dim.
    Not sure what ur goal is, but hope this helps.
    VS980 4G ?
  3. 3TimesMPG
    3TimesMPG Junior Member
    16
    So.Cal
    N2MPG,
    Did you find an answer to your question? I too have been searching here and on the web without luck. The closest I've come is someone installing the lighted door sills tapped to a white wire with a red stripe and another white wire with a yellow stripe. But I haven't been able to confirm.
  4. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    the easiest way would be to run the wire from the actual dome light if you are not able to find the wires in the kick panel
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Wouldn't tapping the dome light circuit result in them only turning on when the door is open? This wouldn't allow the to be on at night. Why not just tap into the parking light circuit
    VS980 4G ?
  6. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    On that thought, one could use a relay wired to the brown wire referenced in the oem foglight installation instructions that would be powered when either the parking/headlights are on.
    SCH-I535
  7. 3TimesMPG
    16
    So.Cal
