LED Headlamp Recommendation
Discussion in 'Prius c Accessories and Modifications' started by LeonG, Sep 29, 2018.
  1. LeonG
    LeonG New Member
    New York City
    Hello, I have a 2012 Prius C II and looking to switch to LED headlamps for the first time.
    Can anyone recommend a good brand that has a compatible fit?
    Also how many bulbs to I need? Do I need four? (two for high beam and two for low beam?) No fog lamp required.
    I just looked at the brand Auxbeam that seems to have good ratings.
    Any advice on selection, price and installation would be appreciated.
    Thanks so much.
  2. Brandon Most
    Brandon Most Member
    116
    70
    Dixon, CA
    2016 Prius c
    I've never tried the Auxbeam brand, but last week I changed my fog lights out to Dragon LEDz, and wow are those things bright. I need to take some upgraded pics with them, but they are just ridiculous compared to the previous Amazon special ones I originally tried.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Consider........the stock lights are good to start with.
    Unless you pay a LOT, new LEDs might not be even as good.
    Unless you replace the entire headlight assemblies, the light distribution might not be good and might end up being dangerous and illegal.
    What exactly do you intend to accomplish with this change ?
    joelg1988 and dubit like this.
  4. Bill Lohman
    Bill Lohman Junior Member
    Stockton, CA
    2014 Prius c
    I beg to differ with Sam Spade 2. I converted my headlamps to LED and it's a dramatic improvement over the already great stock lights. My high beams are amazing now. And the projector lenses are also great with the LEDs. I have the box somewhere...I'll try to find the brand I put in (highs were a different brand than lows). I got them off of either Amazon or EBay (can't remember. Spent around $50, as I recall.
  5. sam spade 2
    7,035
    2,804
    2017 Prius c
    For ALL of the replacement bulbs......4 of them, right ??
    I'm glad that you got lucky.
    I hope that they last for you.
    At that price, I'd be a bit nervous.
    Have you had someone drive the vehicle toward YOU in another car to see how they look to oncoming traffic ??
    michael.sfo and dubit like this.
  6. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    They'll look the same as the regular bulbs... only whiter and brighter, most likely (depending on color of lumen they bought).
    The great thing about the C is that the headlights have the cutoffs built in, so light doesn't protrude upwards into oncoming drivers eyes. This is true with HIDs, LEDs, or the garbage stock bulbs.
    I spent $60 for all 4 bulbs and ballasts and converted to 6k HIDs. Best thing I ever did. Factory bulbs are just terrible with my astigmatism.
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    YOu are assuming that the bulbs are properly designed and were installed correctly.
    And we were talking about LEDs, not HID.
    joelg1988 likes this.
  8. joelg1988
    joelg1988 Junior Member
    34
    32
    Las Vegas, NV
    2018 Prius c
    2012-2014 Prius C headlights have separate bulbs for low and high beam. Low beams use H11 bulbs and high beams use 9005 bulbs. You can buy these very cheap at Amazon, eBay or Lasfit.com, however it's never recommended to change to an LED bulb unless you have projector lights, therefore the low beams you should be okay as long as you get them no more than 4000 lumens per bulb.
    DO NOT change the high beams to LED because the stock headlight assembly uses reflector and LEDs will create glare to incoming traffic. (cops in Nevada love to give tickets for illegal lights because NV has no income tax and they enforce this law that is not enforced in the majority of the US but it definitely exists.) See pic attached. I work for a shop, so I'm definitely very familiar with this topic.
  9. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    You are correct that I'm assuming they are designed to fit in the reflectors for the low beams... yes. With the high beams, as mentioned by Joel, you should not go to LEDs/HIDs unless they are designed to be dual purpose.
    Secondarily, if you installed it incorrectly, then it doesn't really matter what bulb you use... it's going to suck.
    I mentioned HIDs as well, since they are better than the stock bulbs, just like the LEDS. Unless you buy the cheapest LEDS you can buy, this will most likely be true... but then, if you buy the cheapest incandescent bulbs, this will also be true... you get what you pay for in "most" scenarios.
  10. Sam Schnaiter
    Sam Schnaiter New Member
    Taylors, SC
    low beams standard on Prius C were not bright enough for me. I do rideshare at night I need to be able to see well. Working with H ID replacements was truly “HIDeous so bought LED bulbs from Amazon. The improvement was amazing. I see well without blinding oncoming cars.
  11. frenzee
    frenzee Member
    95
    73
    16
    Costa Mesa, CA
    Agreed. I got the highest quality and brightness LEDs money could buy and at 3600 lumens each, it's as if I have a pair of Jumbojet landing lights bolted on. It really makes the car stand out at night, and there is a nice, clean cut-off, so I'm not blinding the oncoming traffic. A couple of months in, I'm still awed every time I turn them on. I Highly recommend it, especially if you have night time vision difficulties.
    priustexasbob likes this.
  12. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    do you have a link?
  13. audiodave
    audiodave Active Member
    800
    272
    US
  14. frenzee
    frenzee Member
    95
    73
    16
    Costa Mesa, CA
    20181116_134022 | PriusChat
    I recommend NOT ordering online from these folks because they may be back ordered, regardless of what the their site says. Call their number and make absolutely sure they have it in stock before giving them your CC number.
  15. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    Buy the Beamtech H11 fanless bulbs from Amazon. I have had them for about a year and a half by now with no problems. The light output is much much brighter than stock bulbs. Also aim your headlights a bit higher it helps a lot, you won’t blind incoming traffic, they point too low from factory.
  16. audiodave
    800
    272
    US
    Any problems with FM interference?
  17. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    I have no problems. I believe I’ve heard about interference but with models that have the cooling fan not the fanless models. I chose fanless because I’ve read the little fans can be heard from the front of the vehicle and I want my Prius to be completely silent
  18. audiodave
    800
    272
    US
    LEDs need some shielding I think otherwise they kill FM reception.
  19. MichaelKnight
    MichaelKnight Junior Member
    39
    22
    Westcoast
    It list this but do verify prior to any purchase....
    Low Beam Headlight H11
    High Beam Headlight 9005
    Beamtech
    I personally don't own these led. But I did assist with the install for a friend. This version was the fanless purchased thru amazon. It relies on passive cooling. It does have a large heatsink at the base. This also did not create any interference with audio. No issues.
  20. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Low Beam H11
    High Beam 9005
    Fogs H16 (same as H11, just lower wattage, H11s will fit in a pinch.)
