Led Headlight Instsall Question
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Darklandscape, Jan 1, 2023.
  1. Darklandscape
    Darklandscape Junior Member
    64
    I am looking to install some brighter lights as I drive at night alot. I have sylvania upper tier bulbs and I could use more light that these.
    I am looking at these ones, or the Sealight ones.
    Do I need any extra parts, or to do any extra modifications to make this work for my 2013 prius?
  2. ChapmanF
    18,567
    I found Sealights to work well, bright and with a good clear cutoff in the right place. But horrid amounts of radio interference, so I had to give up listening to the radio when the headlights are on.
  3. nicoj36
    nicoj36 Active Member
    518
    162
    If you want brightness go with a 55W hid kit. Way better than led.
  4. JSB_99
    JSB_99 Member
    66
    48
    Houston
    I've had the sealight ones from Amazon which were a direct replacement for for the stock halogens about 6 months now. No issues so far and a lot easier than an HID kit which i had in there previously.
  5. ChapmanF
    18,567
    Do you listen to radio much?
  6. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I hope an H9 modified will work better for you…
  7. Slammed
    Slammed Junior Member
    I have them to but I can't see a thing when it rains LEDs are just not correct I'm trying to find a thread on here about converting to an h9 bulb 20230103_154818.jpeg 20230103_200804.jpeg
  8. nicoj36
    518
    162
    Slammed likes this.
  9. Darklandscape
    64
    No radio, but my smartphone is connected to the car via Bluetooth, I use the car speakers for music
  10. Darklandscape
    64
    Are these low beam bulbs?
    Do I need any type of sealant to waterproof the bulbs?
  11. Darklandscape
    64
    I am thinking about trying both options.
    Is there a difference between h11 and 9005/hb3? Do both work my prius?
  12. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
  13. nicoj36
    518
    162
    I’ve tried that and its no better than the LEDs. 55W HID is the way to go.
    Slammed likes this.
  14. nicoj36
    518
    162
    They are low beam bulbs and no sealants needed. Plug it in and good to go
  15. ChapmanF
    18,567
    Yeah, I pretty much had to resort to Bluetooth or CDs or USB sticks, with the LED headlights trashing the radio reception so thoroughly. Leave radio listening for daytime with the headlights off, or when in town listening to very strong nearby stations.
  16. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    The only downside to an H9 is a shorter lifespan, (if properly powered). If there was no improvement there is concern of inadequate wiring. The next step would have been checking the voltage at the bulb during operation, and possible wiring upgrade.
    An HID is not going to have the same output as a filament. The pattern will not match the optics of the lamp. You may be blinding oncoming traffic, or have lowered the aim to the point where foreground lighting is very strong, which constricts the pupils decreasing distance vision.
    The SAE (task force) is working on LEDs, technologically it is supposedly possible to mimic a filament bulb, but still waiting patiently for a true replacement….
  17. PriusII&C
    PriusII&C Active Member
    429
    145
    San Jose, California
    Has anyone used these lights? It is not clear whether the 80W is for a single light bulb or a combination of both bulbs. The OEM halogen light is 55W, and I don't want to have an overheat.
  18. ScottHz
    ScottHz Junior Member
    Kannapolis
    I’ve had an earlier version of these since June 2020 on my wifes 2013 Prius Two, super easy installation, plenty bright (mine were rated at 10,000 lumens). Can’t recall any interference with the radio, we usually listen to our phone over bluetooth or CDs.
    FAHREN Ursprung H11/H9/H8 LED Headlight Bulbs, 14000 Lumens 6500K Cool White Super Bright LED Headlights Conversion Kit Low Beam/Fog Light IP68 Waterproof, Pack of 2
    /d/bYdUBjk
    #18 ScottHz, Jan 14, 2023
