LED Headlight low beams not working, Hi only. Fuse, relay, switch ok.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by devinb72, Jan 9, 2022.
  1. devinb72
    devinb72 Junior Member
    Ohio
    Hey all. I got an 08 Prius that originally had HID headlights. I replaced them with LED about 2 years ago, so they are directly tied into the 12v connection. Recently the Low Beams stopped working, and only the high beams work. I checked the Fuses and relays, all seem good. The switch on the steering wheel is good also.
    I'm not sure what else I can check. Can anyone help me?
  2. Albert Barbuto
    102
    95
    Northeast USA
  3. devinb72
    Ohio
    Thanks for the reply. The bulbs are fine. One bulb works for both high and low beam. I did try another bulb just to be sure an it's the same issue.
    I got the headlights working now, I'm not sure how though. We'll see if it stays working or not.
    ydpplqbd likes this.
