LED headlights for 2012 Prius C
Discussion in 'Prius c Technical Discussion' started by wongnog, Dec 28, 2019.
  1. wongnog
    wongnog Member
    125
    26
    Toronto
    Technology
    I'm looking to replace my headlights with LED bulbs. I got this combo kit for H11 low beams and 9005 high beams:
    Amazon CA:
    Amazon US:
    When I asked the seller if these should work, they replied "...your vehicle's 9005 headlight bulb is shared with your DRL, as the working voltage of DRL is 6-9V, the headlight is 12V, the voltage is different, it is too powerful to light up in DRL model. It may be flickering or not turn on. So if you use 9005 headlights as your high beam, then it may be flickering or not turn on."
    Has anyone run into this issue? I've read about some people needing to add a resistor, but I'm not certain what that means/is?
    I also got these H16 bulbs for my fog lights, but that seems to be a more difficult install so I won't try them yet:
    Amazon CA:
    Amazon US:
    P.S. looks like you may need to turn off adblocker for the amazon links above to appear
  2. icspots
    icspots Junior Member
    Many DRL systems use pulsed power to produce the dimmer light during the daytime, then constant power for the actual high beam. LEDs don’t like pulsed power because they need constant minimum voltage to light up. What you’d likely need is a capacitor harness to plug inline with your lamps.... so the pulsed power would charge the capacitor, and the capacitor would power the lamps.
    When I bought my LED lamps from the retrofit source it gave an option of their anti-flicker harness when I added the lamps. I was just swapping the low beams so I didn’t worry about it. They sell their anti-flicker harnesses separate, $30/pair.
  3. rjdriver
    rjdriver Active Member
    409
    170
    Rhode Island
    For the sake of those of us who are being blinded quite often these days even by OEM LED headlights, please make sure they installed and aimed correctly. .
    #3 rjdriver, Mar 2, 2020
    dubit likes this.
  4. Lee3740
    Lee3740 Junior Member
    Pakistan
    2014 Aqua
  5. icspots
    Honestly that’s true across the board regardless of what’s making the light.
  6. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    I will say sitting in a "c" ....now it seems like everything will blind, but
    for sure all those newer SUV get me all the time.
    Used to only be the old school jeeps and some pickups.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    I think these comments are falling on deaf ears but .........................
    All but the most expensive replacement LED headlights often do not produce the right dispersal pattern and may not even produce as much raw illumination as stock.
    Unless you replace the entire headlight assembly, you can't be sure of a good result.
    And even then they might not actually produce more light.
    Newer isn't always better.
    So IF you drive a lot in rural areas where there is little traffic at night, a set of aux. driving lights would be much easier and likely much better, without sacrificing the stock headlights for urban use.
  8. Jay Chu
    Jay Chu New Member
    Australia
    2014 Prius c
    i-Tech
    Thinking of doing this project as well
  9. icspots
    It’s good to bring up, and true of many headlight kits which swap from a halogen lamp. We swapped out to the LED low beams not for brighter, or whiter, improved beam, etc. We swapped because it’s my wife’s commuter car (100 miles/day) and we’ve had a low beam lamp blow every 1-2 months for the last year. These were just standard H11 halogens, no “fancy” upped wattage lamps that burn themselves to death.
    The beam pattern and light output are similar to halogens, if a bit whiter.
    If I wanted brighter lights or a better beam pattern I’d be swapping out the projector for something much improved. Not planning on dropping that money into this car though.
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    This is odd. Because my family is on our 4th C now over about 6 years and have never had a single bulb go out.
    Does the car get driven at night much ? Because the DRL function uses the high beams at reduced power, I believe.
    You might want to have the charging voltage for the 12 V battery checked.
    It might be a bit too high.
  11. icspots
    No doubt it’s odd. Battery checked out fine, alternator not overcharging. I’ve never had an issue with headlights like this on any other car. DRL is used daily, and yes it uses the high beam lamps with a pulsed power feed. During the winter the car was almost only driven in the dark because her commute was all before sunrise and after sunset. During the summer it almost always driven during the day.
  12. Sonic_TH
    Sonic_TH Active Member
    574
    96
    Puerto Rico
    2016 Prius c
    The Prius C seems to burn the H11 ''low beams'' halogen light bulbs a lot.
  13. abubin
    abubin Member
    193
    92
    Malaysia
    I have done changing all my front lights to LEDs. Headlight H11, highbeam 9005, foglight h11 and front side marker t10. Rear all are leds too. Except for the signal light as that will get hyper flash. So far, loving it and I made sure it's not blinding to the oncoming traffic.
  14. hybird
    hybird New Member
    Where did you get your lights? I'd love to make all of these conversions as well.
  15. BiomedO1
    BiomedO1 Senior Member
    4,112
    2,155
    SacTown, Ca
    Ebay or amazon. the DRL will flicker, unless you install an anti-flicker harness. I didn't see the point, since the DRL is supposed to get you noticed. Had them in the car for 5 years, no issues - until an uninsured motorist totaled it out.
    PS. you need to watch the polarity on LED's; incandescence lamps don't care which wire is positive or negative, but LED's do. If your replacing your fog lamp bulbs; get the 3000K bulbs - they're yellow, a great contrast in the fog, rather than the blinding full white light spectrum.
    Good luck....
  16. Sonic_TH
    574
    96
    Puerto Rico
    2016 Prius c
    What did you used for the high beams on the front? did you changed the housing? otherwise the halogen housing will project the LED headlight light in an inefficient pattern, not shining the front at all, scattering the light too high, blinding anyone in the front.
  17. YoYo
    YoYo Junior Member
    ACt Australia
    2015 Prius c
    i-Tech
    LEDs are a bad choice of light. Unless you can get below 4000kelvins from memory. The light is too white. It makes you tired on long drives, gives no depth of vision so everything is like looking at a photo instead of being able to gauge distances in 3d. The light bounces of smoke, fog, dust and street signs. It looks bright, but in actual fact testing agains HID, Halogen etc, you cannot see as far. This is what I have found from research and experience with years of four wheel driving. There's a reason you don't see them on most trucks here in Australia accept for maybe short distance wide spread light bars for the close range and edge of road. I would get a number plate light mount bracket and some small spot lights if you want better lighting. But you will find new stock bulbs will also be much brighter than ten year old ones. I believe even the auto makers have gone away for LEDs now, at least high beam, not sure on low, probably LED for fog and maybe indicators and stops.
  18. Sonic_TH
    574
    96
    Puerto Rico
    2016 Prius c
    On the Prius C you can get better low beam illumination without replacing the entire headlight assembly. I replaced the low beam H11 halogen bulb on a Prius C, for a Sylvania H11 LED bulb, and now the low beam illumination is better than before, and it does not blinds those who are coming the opposite direction. My high beams are still halogen, i can't put LED bulbs in there because it is not a projector like the low beams, so the light will go all directions blinding everyone in front.
  19. priusbydefault
    priusbydefault Junior Member
    39
    El Monte, CA
    I have replaced all bulbs including interior and exterior flashers. I needed to change the flashers relay to a different one to prevent hyper flashing.
    I disagree with comments stating that LED headlights do not provide good depth perception at night. With halogen bulbs, I could not see comfortably enough during night driving and constantly feared I would hit an object dropped on the road by another motorist. They were so dim and too orange colored. Could barely see 5-10 ft in front of me. Now with LED bulbs, I can actually drive at night without worrying about what's out on the road ahead of me. I can see everything. I don't even have to turn on my high beams during very dark roads anymore. They seem to be 10 x's brighter than stock halogens. I love them. I've upgraded my daughter and wife's cars with LED bulbs in their headlights as well and they absolutely love them. I truly believe LED's are much safer and can help avoid road safety hazards.
    I am constantly shined on by oncoming drivers bright headlights and don't mind it at all. I figure they need to see as well. I feel everyone should have them. If you do upgrade to LED though, please attempt to align them as low as possible to limit shining other drivers directly in the eyes.
