LED indicator bulbs... fast flash? Need different flasher?
Discussion in 'Prius c Main Forum' started by curtis73, Mar 31, 2025.
  1. curtis73
    curtis73 New Member
    Harrisburg PA
    Searched, but didn't find the specific answer. Just got my 2012 C a few weeks ago, and one of the things I like to do on my cars is upgrade all of the turn signals, brake lights, and interior lights to LEDs. I like that they're brighter and tend to last longer. Curious if I'll need a new flasher?
    I found that some C's came with LEDs, but mine didn't... or someone replaced them with incandescent somewhere along the way.
  2. Tideland Prius
    16,445
    For indicators, you typically need a load resistor if you don't want the indicators to flash faster.
    Otherwise, for taillights/brake lights, a straight swap is fine. Ditto interior lights.
    The Prius c has a mix of incandescent and LED lights. I can't remember if the brake lights or taillights are LEDs from the factory (I think it's the brake lights... the 4 dots in the circle). In that case, you can swap out the taillights, licence plate lights, parking lights and indicators.
  3. curtis73
    curtis73 New Member
    Harrisburg PA
    Good to know. I was following my Prius (my friend was driving it) last night and noticed that the brake lights were LED but the running and turn lamps were incandescent.
    Dumb question (because my next-newest vehicle is a 1996 Chevy)... is the load resistor what they call the "can-bus" lamps?
  4. Tideland Prius
    16,445
    Err, that I'm not sure. Maybe someone else here might have an answer to that. I've swapped out my interior lights to LEDs and my taillights (on the Gen 2) before but never the indicators.
  5. Paul Gregory
    Paul Gregory Senior Member
    1,508
    391
    Alberta
    2024 Prius Prime
    XSE
    I put load resistors in the tail light circuits on my Gen 3 when I installed LED bulbs. I found out I didn't need them when I swapped the incandescents back in. No change in how they performed, despite the higher current draw. The blinker rate must not be dependent on current draw.
  6. curtis73
    curtis73 New Member
    Harrisburg PA
    Revisiting this. I installed resistor-type LED bulbs last week. I'm getting fast flash.
    Looks like I need a flasher as well. Grrr.
