LED lamp repair???
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by jzchen, May 31, 2017.
  1. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Well. After noticing the washer fluid dripping onto the floor I opened the hood to see what I could see.
    Low and behold some attachment points of the right LED headlamp seems damaged. The lamp is loose. I found these repair mount parts, that seem to be just for the occasion, and ordered a set for both sides, just in case.
    Still waiting for parts to come in so:. To be continued....
  2. xliderider
    xliderider Senior Member
    7,872
    3,116
    Honolulu, HI
    Was there an accident?
  3. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Don't know. Maybe someone hit the car while it was parked, and then left the scene, I'm afraid....
  4. xliderider
    7,872
    3,116
    Honolulu, HI
    Where was the washer fluid coming from? Cracked reservoir, or damaged fittings?
  5. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    There was a crack in a hose coming from one washer pump. Maybe whatever damaged the liner may have pressed a screw into the line. I added split loom around the replacement hose to help protect it from happening again.
