1. Server migration is complete! Check out this thread for more details and to report any bugs.
LED turn signal bulbs w/projector lens
Discussion in 'Gen 3 Prius Accessories and Modifications' started by striker308, Aug 16, 2012.
  1. wotcher
    wotcher Member
    403
    97
    16
    LA
    i thought you were getting valentis.
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,291
    Palmdale, Ca
    He would still need the LED flasher relay cause he's changing the front turn signals to LEDs as well.
  3. wotcher
    wotcher Member
    403
    97
    16
    LA
    too bad the revier led corner 2012 doesn't fit.
  4. SCRWGas5
    SCRWGas5 New Member
    156
    Charlotte, North Carolina
    Yeh that's right. I need to swap out my front turn signals. Down there on the front bumper. Anyone got suggestions of a good bulb?
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I can tell you which ones not to buy... I got these from JDM toy and they are not bright enough by a long shot.
    Probably some 7w projectors I would think might do the trick...
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,291
    Palmdale, Ca
  7. SCRWGas5
    SCRWGas5 New Member
    156
    Noted. That is just as valuable as which ones to buy actually.
  8. SCRWGas5
    SCRWGas5 New Member
    156
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,291
    Palmdale, Ca
    I was thinking about it. It would require a change in the bulb socket to accommodate the 2nd pole(which are different between the 10-11 vs. the 2012) & hooking the up to the OEM DRLs.
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    That's what I thought.... thanks.
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,291
    Palmdale, Ca
    No prob.
  13. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    I tried the JDM bulbs and they were not even close to matching the brightness of the original incandescents. I just got through installing these and am really happy with the brightness:
    Tail Light Brake Light Turn Signal LED Bulbs
    I have the 12W version of the Eagle Eye SMT Tower fixture. I couldn't see the benefit in going with the 14W version because the extra wattage is on the end of the bulb, which actually faces out to the side of the car with the way the bulb fixture fits into the housing. Most of the forward-facing light comes from the LEDs on the side of the bulb fixture, which has 3 x 3W LEDs, the same number and wattage for both the 12 and 14 watt bulbs.
    iPad
  14. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
  15. sfv41901
    sfv41901 Masta S
    4,591
    5,291
    Palmdale, Ca
    Yes if I had the white part hooked up.
    This is the LED flasher relay
    Toyota Lexus 8 Pin 12V Electronic LED Flasher Blinker Bulbs Relay Fix
  16. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    Well I finally got the bloody relay in! You are not kidding about PITA!!!!!!
    I couldn't get the OEM one out so I unplugged it and ziptied the new one to a buch of wires up there.
    changed the bulbs with the ones from eBay with the projector on the end and now I'm all LED/HID (other than the high beems)
  17. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    So which bulbs and how is the performance in the daylight hours?
  18. sfv41901
    sfv41901 Masta S
    4,591
    5,291
    Palmdale, Ca
    Congrats.
    Are u sure ur all LED? U got the bulbs behind the amber reflectors?
  19. striker308
    302
    43
    Spiderman - These are the bulbs and you can't tell they aren't the OEM bulb. They even look brighter to me.
    2X Amber 7 5W 5 SMD LED T20 7440 Turn Signal Side Marker Tail Light Bulb Yellow | eBay
    Even with the front two mounting sidways they still look just as bright.
    sfv41901 - yes I remembered the ones behind the amber reflectors and the license plate lights.
    Right now I'm working on mounting five smaller t-10 style projector bulbs flush in the doors that let you get to the license plate lights so they light up with the cargo lights.
    2X SMD LED 2W T10 WY5W W5W 194 168 Car Dome Dashboard Projector Lens Light Bulb | eBay
    I just need to figure out how to mount them. I'm testing setups on an old hatch trim peice before I do it for real.
  20. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ? what do you mean?
    So in the daylight, even with the sun shining on them, you can still make them out? The ones I have are completely obliterated by the sun light and can tell if they are on or not. :(
    How long was the shipping time?
