LED Turn Signals and Backup Light
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Rishar, Apr 25, 2018.
Tags:
  1. Rishar
    Rishar Junior Member
    US
    Thought I'd share my experience with changing to LED turn signals and reverse light for a 2016 Gen 4 Prius.
    I'd also like to share my disdain for whoever designed placement of things in the engine compartment making it very difficult to change the front bulbs.
    The short of it is, it works, there is no error message from the car. They do hyperflash, as expected. I don't really see it as a problem though. Far as I know, not against the rules. And might even give me the chance to make some police friends when they pull me over to see if the side they couldn't see is working, since fast blinking usually indicates a bulb out. :p
    In a few other threads, saw some comments and questions about what is and is not LED. The turn signals, all interior lights (except the light shining towards shift handle) and the lights underneath the door are all incandescent. Personally, I find this irritating, I would not have made much fuss about an extra 200 dollars for all around LED lighting. The only ones I have left to do are the under door lights.
    I did take plenty of pictures when I did the conversion to LED, both the front and back. If anyone is interested, I could post them with a quick guide on getting at everything.
    There is one interesting thing to note. When you set the lights to parking lights on the turn handle (one after DRL), with incandescent bulbs, the turn signals light up very dimly. The LEDs that I installed, Sylvania Super Brights from local parts store, do not light up. I'm assuming they require more current before they actually light up.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    You'd not get away with it here.
    The regulations here state clearly "Every modification of a type of direction indicator shall be notified to the administrative department which approved the type ..." - and needs to go through the entire testing process, which includes photometric measurements of intensity at various angles both horizontal and vertically, as well as colour compliance. It also specifies "the light flashing frequency shall be 90 ± 30 times per minute".
    There is a similar regulation for reversing lamps, as they must be such that they don't blind other drivers etc etc and must be compliant with what was supplied with the vehicle.
    A car which doesn't comply with the approval mark's status would be able to be put off the road till it complies. And, in the case of an accident, could be deemed unroadworthy - and at fault - insurance companies look for the smallest reason to deny a claim.
    Harters likes this.
  3. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    Same here in the UK
    Replacement external LED bulbs are not allowed unless they are fitted to the vehicle from new. I would like to make the change, but know that I would be breaking the law if I did.
    I have replaced all my interior bulbs with LEDs though as they are not covered under the same law as they are not exterior.
    It is a shame that the flashers/reversing lights are not LED as the Prime/Plug-in is, but I guess they want there to be differences/upgrades between the models.
    JayGen4 and alanclarkeau like this.
  4. alanclarkeau
    7,045
    7,593
    I suspect that PRIUS was an earlier design before LEDs were common, but TOYOTA put LED headlights and taillights as a "new" technology showpiece - plus it's really neither here nor there what bulbs are in an indicator or reversing lamp - they're not on continually, unlike the taillights or headlights which are great to have as LED. PRIME is a newer design, and LEDs were more common by then.
    A couple of years ago, guys started putting bright HID or LED bulbs in their old cars, which focused poorly annoying other drivers (& police) - and many got defect notices and fines - $126 at the moment. In some cases, a car which is identified as defective has to be removed by flat-top truck, though not sure if that would happen with lights - does if they catch a driver with bald tyres.
    Harters likes this.
  5. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    I really want to do this too. Are you happy with the LEDs you chose? Any recommendations on where to get them in the UK? What sizes do you need to do all interior, boot, and under-door lights?
  6. Harters
    335
    427
    UK
    Excel
    I bought them back in 2013 when I had a Q5, so when I sold that I transferred them into my Zoe and then into my Prius.
    I got them off eBay and chose a super bright white. I can’t remember what temperature they are, but they are a very white which is what I wanted and do not have a blue tinge like some have.
    The only bulb I had to get extra for the Prius was the rear dome light as it’s a shorter festoon type than I had in my selection. I got it off eBay for about £3. All the other bulbs are small push in type.
    It’s really worth doing as it transforms the interior and now I can actually see what’s in the boot!
    I have got some logo projector lights coming from the US for the bottom of the doors.
    #6 Harters, Apr 26, 2018
    alanclarkeau and The Professor like this.
  7. The Professor
    598
    809
    UK
    Excel
    Thanks for the reply. Much appreciated.
    Pixel 2 ?
    Harters likes this.
  8. Rishar
    US
    I didn't realize other countries had such strict rules on the lighting. Some states here in the US do, mine is not one of them, though there are some. Only white/amber lights allowed on the front, red/amber/white in the back. That's about it, other than headlights having to be aimed correctly so as not to bother other drivers. They could probably get you with that one if they're too bright and bother them.
  9. Tideland Prius
    16,623
    They would've been co-developed. Honestly, I thought what we saw on the Gen 4's taillights would've been incorporated in the Gen 3. I was a bit disappointed that they still went with the LED "tree" design that was similar to the Gen 2. It was still functional and it worked with the design but I thought they might've gone a different way.
    The Prius had LED brakelights since 2003/2004 (2nd Gen). Then for Gen 3, it was upgraded to both taillight and brakelight (really, just the dual brightness LEDs) and also LED low beams were added for Gen 3 (only on the I-Tech model in Australia). Gen 3.5 added LED parking lights to models equipped with LED low beams.
    A number of European countries don't allow mods - even something as swapping to aftermarket rims are not allowed.
    In the US, there are different lighting laws - for example, the US doesn't allow adaptive LED array headlights (the ones that can shine both low and high beam at the same time where the low beam is shone towards oncoming traffic to avoid glare but shines high beam elsewhere to maintain illumination. With LED technology, you can increase/decrease the brightness of each cluster of LEDs). It also doesn't allow for progressive turn signals (you can see Audi and Toyota get around that law by including a traditional blinker with their progressive lights).
    alanclarkeau likes this.
  10. MagnusAG99
    MagnusAG99 Senior Member
    673
    521
    Norway
    I honestly think the rules we have for car lights is ridiculous, in Norway we got the same law for lights as in Australia. And i dont see the point... Its many LED bulbs thats not much brighter then the original bulb, but still the car needs to go thru a checking thing at the states road authority. What a waste of time, should come a new rule, u r only allowed to install LED bulbs thats E-certified, now that wouldve saved time. For both the road authority and us, since LED`s light up faster i prefer LED. In all my cars thats had normal bulbs for brake lights ive always changed to LED bulbs, couldnt care less about the law when it comes to brake lights thats supposed to blind the car behind u. Should be a law that says car manifacturers r not allowed to make bulb-brakelights on any new cars, only LED, i see that on most new cars the third brake light is LED, but i dont think that is enough.
    i dont see the point of not being allowed to change to LED`s in reverse lights either, its SOOOOO many ECE certified aftermarket reverselights that blinds so bad, theyre like spotlights. But they r ECE certified so they r legal, but my LED reverselights that dont blind half as much is not.
    And does it seriously exist countries that dont allow aftermarket rims? ive never heard of that and i live in a EU country, or well... We r not part of the EU they say even tho we got the exact same laws as EU countries. But yea, that is rediculous, some power hungry people controlling whatever country that is then lol.
