Led turn signals question
Discussion in 'Newbie Forum' started by tarapajero1, Jan 8, 2013.
  1. tarapajero1
    tarapajero1 New Member
    Some websites recommend a pair of load resistors for LED turn signal lights. Will it work or burn out faster if I don't get load resistors?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    The load resistor is merely for the flasher relay. It will hyper-flash without a standard load. LEDs take a less load then the OEM incandescent bulbs.
    The alternative is to replace the flash relay with one the supports LEDs. The problem with those, is they won't hyper-flash if you have a burned out bulb.
    Welcome aboard by the way!
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Here is a pic of the relay in my Gen II. I believe Toyota pretty uses the same relay in multiple vehicles.You can get them from JDM, pop it it, LED away!
  4. scottmcphee
    scottmcphee Junior Member
    22
    Shows the side tabs to cut, then pop this one in! [​IMG]
    (google tapturn flasher)
    KK6PD likes this.
