Left my 2014 Prius 60 days so far.....
Discussion in 'Gen 3 Prius Main Forum' started by GaryHere, Feb 9, 2015.
  1. GaryHere
    GaryHere Member
    147
    27
    Arizona
    Had to go to my Dad and no one attending to my car
    From what I read, someone had one start up after 60 days so Im hoping it will start but no prob, can jump start.
    Anyone go this long and can comment?
    Will update on Wednesday when home the conditions of both batteries.
    Left hybrid battery at about one line above middle.
    51,154
    hybrid battery will be fine. if you've never run down the 12 volt, it should be fine as well. i leave mine for 35 days every winter, even when 4 years old. and my 08 still has the original battery.
  3. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
  4. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Mine will be 65 days when I arrive home March 17 th.. I have a 2 amp. Smart charger on the 12 volts. Hal
    Jon Hagen likes this.
  5. bisco
    51,154
    well that's no fun.:p
  6. GaryHere
    GaryHere Member
    147
    27
    Arizona
    I didnt leave anything on it, no charger etc, had to leave very fast.
  7. HaroldW
    716
    95
    You may be good. You will soon find out. Hal
  8. GaryHere
    GaryHere Member
    147
    27
    Arizona
    Thanks, yes thats true.
    Will report back the findings soon enough
  9. HondaTheNextOne
    HondaTheNextOne Junior Member
    45
    Tennessee
    This has me wondering... How long can a Prius sit without being started?
    2 weeks?
    A month?
  10. GaryHere
    GaryHere Member
    147
    27
    Arizona
    The longest I read from the search function/google was 60 days and started right up.
    Dealer said 12v would be dead in 2 weeks but theres folks who started the car way longer.
    SKS I think disables itself in 5 days ?
  11. GaryHere
    GaryHere Member
    147
    27
    Arizona
    This was the first time its left alone and unstarted since I got it. It was used each day.
    Good to know hybrid batt will be ok.
    Is the 12v covered in warranty? Dealer said its 90.00 for new one.
    thanks.
  12. bisco
    51,154
    the 12 volt has it's own specific warranty, usually pro rated. i'd be surprised if they sold you a new one for $90., they probably are thinking a typical car battery, but when the look up the prius part, find out it's $200. plus labor.
  13. Mendel Leisk
    40,583
    I'd move fast on that, before someone comes to their senses, lol.
    Seriously, someone got confused: the battery from the parts department will likely be around $200, or a bit more. Plus a charge that's refunded when you return the old one (core charge).
  14. GaryHere
    GaryHere Member
    147
    27
    Arizona
    lol yea sounds too cheap, eh a salesman told me that, wasnt in service.
    Guess I will know tomorrow night when I return if it starts.
    thanks all for the replies!
  15. GaryHere
    GaryHere Member
    147
    27
    Arizona
    Car started right up, lights were bright, hybrid battery, no change, still at same bars
    Thank you for the replies!
  16. Blizzard_Persona
    1,787
    946
    Pa.
    2023 Prius Prime
    XSE
    Good to know.
    Wondering what people that leave on extended deployments, etc have to do? Battery tender?
  17. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    I am also wondering, since my Firebrid project will be down for extended periods while I am welding the two bodies together. For the 12 volt, I can always swap it in and out of my other 2 Prii, but I am wondering if I need to worry about the Hybrid battery while it is out of the car. Batteries and electronics all need to be removed during the MIG welding to prevent electrical surge damage from the arcs.
    Bill the Engineer
  18. bisco
    51,154
    how long will the hybrid battery be out of use? you might need a grid charger.
  19. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    It depends on many factors, most significant is what condition your battery is in. A new battery is rated at 45 Ah, and the Prius has a parasitic draw of 0.013 A (I measured). 45 / 0.013 = 3461 hrs = 144 days.
    You wouldn't want to sit even half those many days because permanent damage to the battery will occur.
    If the car will sit parked for a long period of time, either disconnect the battery, or put it on a float charger/solar charger.
  20. macman408
    macman408 Electron Guidance Counselor
    1,179
    367
    The manual states that you should drive the car for 30 minutes or 10 miles "at least once every several months". Will it take you longer than 3 months? A little bit longer should be fine, especially if you store it with at least the usual 6 bars. I wouldn't go more than 6 months, though. A nearby dealer might be able to charge it for you, although I've sometimes gathered that the charger for these batteries is something that's so rarely used that they ship it from dealer to dealer only when it's needed.
