Left my charging cable at home
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by terrylowe, Apr 30, 2012.
  1. terrylowe
    terrylowe Junior Member
    79
    24
    Mississippi
    OK...it only took three weeks for it to happen.
    While in a crazed caffeine withdrawal state, I unplugged my car at home and made it all to the way to work before realizing I left my cable at home. Drat!
    51,157
    i hate when that happens!:D
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Isn't it still nice to get 50+ MPG with regular gas?
    This is a good opportunity to see how many MPG you get without a recharge back home.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    You need a longer cord; then you could leave it plugged in.
    Tom
  5. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
    Here is another reason to invest in a L2 EVSE that's installed in your garage, the Toyota supplied EVSE would still be in your trunk :)
  6. terrylowe
    79
    24
    Mississippi
    That's and idea! A trolley prius!!!
  7. jackiemac
    jackiemac New Member
    San Francisco Bay Area
    Inevitably, I fear I'll forget mine too. :)
    Anyone know know of a good place to purchase a spare charging cable?
  8. iRun26.2
    iRun26.2 Active Member
    772
    153
    United States
    Agreed! I haven't done the same thing yet, but I'm sure I will eventually. Just having to pack/unpack it once per day makes the EVSE installed in my own garage almost worth it.
    Is really like an L2 option at home because there are many times I'd like to go someplace but not to have to wait 2.5 hours for a full charge.
    2 good reasons is pretty convincing!
  9. fjpod
    fjpod Member
    419
    72
    New York
    I've heard those things are expensive...even just the 110 volt models, and forget buying one from the dealer, upwards of $750 I am told.
  10. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Someone checked with the dealer for the Toyota one and I recall it was something like $1200 or $1500. If you're serious about getting an extra cable/EVSE, check out EVSE Upgrade - Products. They sell a Nissan Leaf EVSE/cable already modified for 110V/220V use for $979 and it has been confirmed that it will work with the PiP (I believe hill has one).
    This is the option I would go with.
  11. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    I have left my charging cable behind so many times, it drives me nuts.
    Sometimes it was intentional, and then I regreted it later, sometimes I just forgot to grad it. Either way it's becoming a PITA and I can't wait to get my L2 hooked up.
    You got that right! And lately I've been wanting shorter turn around times between charges. With L2 I can get back on the road with a full charge in half the time.
    The price of any spare L1 pretty much exceeds the cost of a L2 charging station. Makes L2 a no-brainer.
  12. ThatTallGuy
    ThatTallGuy Junior Member
    67
    Southern NH
    My dealer quoted $1200.
    I am waiting to find out if the $350 Chevy Volt (third time around) cable charges the PiP. (Watching here: http://priuschat.com/forums/toyota-...hevy-volt-110v-charge-cord-3.html#post1516358) Hoping it does. If not, I'll go the OpenEVSE route.
  13. terrylowe
    79
    24
    Mississippi
    Ok Mitch, I'm in. Gonna build one
  14. ultraturtle
    108
    81
    Peachtree City, GA
    The Leviton L2 unit recommended by Toyota is only $870 plus $25 shipping. I ordered mine a week ago from Garrett's:
    Smart Electronics Product
  15. mitch672
    1,077
    198
    Randolph, MA
    You might want to order the installation kit as well, comes with the bracket, outlet, and water resistant outlet cover
  16. ultraturtle
    108
    81
    Peachtree City, GA
    It's not needed for my situation, nor for many others'. The bracket is not needed for mounting, I don't need the outlet cover since the unit will be installed in my garage, and I already ran the 240V line to the outlet which I picked up at Home Depot along with a cut-in box for about $3. I could not justify paying $75 for the installation kit, when all I needed was about 3 bucks worth of its parts.
    My total installed cost was $898 plus the cost of the breaker and some 12ga romex.
