Left Reading Light On For 3 Days Straight
Discussion in 'Gen 3 Prius Main Forum' started by crellion, Jan 5, 2012.
  1. crellion
    crellion Junior Member
    48
    Has anyone done this dumb move where they left their reading light on in their Prius without noticing for a few days?
    I just noticed it today on my 2010 Prius and freaked out that I drained the battery. :(
    It started and drove normally thankfully.
    However, I am concerned whether I shortened the overall-life of the battery doing this or if I actually burned a hole in my reading light or something from that constant "ON" state.
    I know that unlike the Dome Light, the Reading Light will stay "ON" forever until you pushed it "OFF."
  2. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    I've left it on overnight, but not for multiple days. If you are concerned and try this procedure to check your battery:
    Toyota Prius 12 Volt Auxiliary Battery with install kit for 2004 - 11
    I think it will start and drive normally for the most part even if the 12V battery is weak. Occasionally, you may see a MFD warning message saying something about the brake and parking on level ground when the voltage is low. I got this several times while I was parked and didn't think too much of it. Finally, I got the message while driving and I lost ICE power until I pulled over and restarted the car, which convinced me to research the problem and verify/replace the weak battery.
  3. crellion
    48
    The good news was it was only the left driver-side Reading Light - and not both lights.
    Also everything else was turned-off...
    Still - I wonder how much energy that little light can drain?
    I also only have Prius II model so I can't access the Maintenance Mode to find the voltage of the battery...
    Should I leave my car on for a while to recharge it or what?
  4. ryogajyc
    985
    165
    Reseda, CA
    From the instructions I previously linked:
  5. crellion
    48
    Again, doesn't that require the NAV package with the touch-screen? My Base Prius II doesn't have any of that - so I don't think I can even get into that Maintenance Mode...
    I read somewhere the only way I can figure this out is by a Smart-Meter or something....
  6. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    I believe the 12V battery in a Prius is a deep cycle battery that can better stand deep discharge cycles than a conventional starting battery.
    Just fully recharge the battery as soon as possible and all should be well. Drive the car for an hour with minimum high drain accessories on should get it near full charge.
    When weather / snow conditions are bad I park my gen 3 Prius (2010)for as much as two months with a small charger / maintainer / desulfator connected to the battery through the under hood boost start terminal in the fuse box.
    The model I use is the BatteryMINDer brand sold by Northern tool company. This is a very good unit that will slowly recharge the battery, maintain it at full charge and remove any battery damaging sulfation caused by an accidental discharge like you had.
    The BatteryMINDer is safe for all battery types including sealed and AGM types.
    I have 4 of those units I use to maintain the batteries in my fleet of cars, pickups and farm equipment.
    BatteryMINDer Charger/Maintainer/Desulfator — 1.3 Amp, 12 Volt, Model# 12117 | Battery Maintainers | Northern Tool + Equipment
  7. ryogajyc
    985
    165
    Reseda, CA
    My quote is still relevant. If you've driven your car for 30 minutes, your battery is fully charged regardless of whether you have the touchscreen.
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I doubt those steps will work on a Gen 3 (2010-2011) Prius as the color LCD (aka MFD) is NOT standard on Gen 3s. You only get it if you have nav. Navless 2010-2011 Priuses don't have an Info button, AFAIK.
    For those w/nav, I'm not sure those steps work. Hopefully someone w/a Gen 3 w/nav can confirm.
  9. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Not so dumb actually, could happen to anyone. For me the key statement is the one above, if it had enough energy to start the car I think it will be fine.
    Discharging the battery once and a while doesn't hurt it, it's designed with that in mind. Running it completely down to the point you need a jump to get into the ready mode might shorten its life.
  10. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Well, the Prius battery DOES NOT "fully charge" after 30 min of driving. Unless it was almost fully charged when you started. A drained battery will take 4-8 hours of "ready" to fully charge.
    If you have the car in "ready" for an hour each day it will return to a normal charge level after a few days to a week. I wouldn't worry too much about it unless you leave the car unused for days after this kind of "drain event".
    As stated above, it still allows the car to go to "ready" so is probably just fine.
  11. fuzzy1
    10,167
    You are correct, our 2010 Nav-less models don't have the buttons and displays called out by this procedure.
    And several resident experts have previously stated very clearly that 30 minutes is not enough to fully charge the battery.
  12. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    If I am not mistaken, and speaking from memory, the rear dome light can be also left "ON", if so, take care after your child (or grandchild) played with it.
  13. crellion
    48
    Also on a little off-topic, and this may seem silly but can leaving a tiny Reading Light in a car for days actually "burn" anything in the plastic encasement of the Reading Light itself in the car?
    I never in my life left a light on for a day, much less for 3 days straight and wonder if it tends to fry any component in the car, or if a simple bulb-replacement should fix whatever problems I have?
  14. tumbleweed
    4,067
    687
    Eastern Oregon
    Does the light still work? If it works OK and looks OK it is OK. Interior light bulbs usually last the life of the car so don't worry about it. If it is burned out I think there may be instructions in the owner's manual for replacing the bulb.
    If there really are signs of burning or melting I think you would need to find out what went wrong, you should be able to leave that light on indefinitely without those kinds of problems.
  15. trueaspects
    trueaspects Junior Member
    27
    what exactly is the "reading light"? is it the same thing as the interior dome light?
    http://kyoei-usa.com/blog/wp-content/uploads/2011/05/Prius_Luxer1_after.jpg
    that is the dome light correct? and even if these are left on, they automatically shut off after 20 mins or so? or is the dome light the rear seat one?
    or is the map light, the light that shines over the shifter? (if this is the reading/map light, how does one control this? i thought it was always automatically on when the car is on)
