Left-side lower control arm replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by p4nzy5bud, Nov 16, 2018.
  1. p4nzy5bud
    p4nzy5bud Junior Member
    Murrieta, California
    I am trying to replace both the left and right lower control arms on my 2007 Toyota Prius (180k miles) since there is a creeking sound whenever I go over bumps. The right-side is difficult in that the engine is preventing me from pulling out the screw to remove the control arm. Any ideas?
    (Typo: not sure how to edit the title using my iPhone but I meant right side not left.)
    52,390
    if no one knows, the service manual is at 'tech info.toyota.com'
  3. Patrick Wong
    18,210
    6,513
  4. audiodave
    audiodave Active Member
    800
    272
    US
  5. Patrick Wong
    18,210
    6,513
    Or front engine mount removed so engine can be slightly jacked up.
  6. jessiejosco
    jessiejosco Member
    62
    42
    I just did this 4 weeks ago. There are just 2 bolts holding the subframe on each side that you can get at easily. I put a jack under the right side and took the right bolts out and then dropped the jack down. Then I had to gently pry the subframe down to slip the front control arm bolt out.
    One thing I learned the hard way is that when you are torquing the control arm bolts you need to at least put the car down on its wheel and load the arm to settle in the bushings, before tightening the bolts. I actually used a jack to load the control arm at about ride level and torqued the bushings loaded. If you don't do this you may get play and noise from the front bushing even with a brand new control arm, like I did.
    audiodave likes this.
  7. audiodave
    800
    272
    US
    Did you complete the job and get rid of the creek? I replaced mine because it sagged and couldn't be aligned. I get creeking but pretty sure from sway bar bushings.
