Left the headlights on...car won't turn
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Erin Riel, Dec 29, 2017.
  1. Erin Riel
    Erin Riel New Member
    28
    Massachusetts
    Left the headlights on...car won't turn on.
    I'm remembering now that I turned the car off, and turned the headlights back on so my mother could see her way on the ice to the house more easily. Welp then I forgot to turn the lights off. Three hours later I noticed, turned the light off, attempted to turn the car on, power button was green, pressed it, nothing happened, pressed again button turned red... And the check engine light turned on and switched back off again.
    I guess I need to jump it, but can it wait till the morning? Or would the over night temp of less than 5 degrees Fahrenheit do damage to the already dead battery?
    Extra info: Im a brand new Prius owner (two months) also barely overdue for an oil change and have one scheduled for just after the new year (Wednesday 1/3/18). Thank you!
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    You won't do any more damage, but a simple jump start may not work if your battery is too far gone.
    Guess it also somewhat depends on what the health of the 12v battery was before the incident.
    FYI the 12v battery is in the trunk area.
    But there is a jump start terminal under the hood.
  3. scona
    scona Active Member
    225
    206
    Courtenay, BC, Canada
    2013 Prius v wagon
    Ideally you would boost the car and get it started tonight. But that is hardly practical for you as a new owner to do in the dark at your cold temperatures. If you were a AAA member it might be worth a call to see if they would come out. If not I would leave it to do in the morning. Use this evening to do a search here on boosting the Prius and how to do it. It is different than other cars and if it is not done correctly can do a lot of damage. Any more questions and come back here to get answers, there are lots of people here who can help.
    Erin Riel likes this.
  4. Mendel Leisk
    40,584
    I would get it on a smart charger, 4 amp range. It'll likely take up to 12 hours, considering the depleted state.
    Assuming you're able to restore it, start monitoring, at least the voltage, with a digital multimeter, with the car off. If it will stay above 12.6 it'll be ok for a while. Testing it with Solar BA5 or similar will give you a better idea of what to expect, if it's worth sticking with it or replacing.
    Erin Riel and scona like this.
  5. bisco
    51,154
    welcome!
    same thing happened to my daughter two nights ago in our driveway. i was able to charge it overnight, and drive it to the local mechanic to have a new battery installed. if yours is original, you should buy a new one.
    if you don't have a charger to get it going, be careful jump starting. cross polarizing the leads can do serious harm.
    all the best!(y)
    Erin Riel, scona and Raytheeagle like this.
  6. Erin Riel
    28
    Massachusetts
    The battery is practically brand new, replaced this month at the Toyota dealership
  7. Erin Riel
    28
    Massachusetts
    I've been checking up on a number of YouTube videos for the proper steps to jumping a Prius and I'm feeling confident! The 12v battery is practically brand new, just replaced at dealership this month
  8. bisco
    51,154
    in that case, you need to charge or jump it. but even a new battery drained in this weather may be toast.
    if you can't get it going, there is a warranty.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Do you have the owners manual for the Prius?
    It describes the process there(y).
  10. Erin Riel
    28
    Massachusetts
    Yes! I'm using both
  11. Erin Riel
    28
    Massachusetts
    No kidding? Wow! That's frustrating
  12. Erin Riel
    28
    Massachusetts
    Thank you! It's a very new battery (replaced this month) so I'm hoping that bodes well for the situation
  13. bisco
    51,154
    brutal cold. very hard on batteries, especially when drained. i think the new toyota 12v gets a 2 year unconditional warranty, then prorated.
  14. Erin Riel
    28
    Massachusetts
    So would you be recommending I try to jump it tonight? As opposed to the morning?
  15. bisco
    51,154
    yes, the sooner the better. but if it's too cold, and you don't feel like it, i don't blame you. worst that happens is you get a new one free.
  16. Erin Riel
    28
    Massachusetts
    With the cost of replacement :/ grand scheme of things not the worst problem to have. Unfortunately I'm not able to get anyone in my house to assist me tonight, and I'm not feeling super confident about the whole ordeal by myself
  17. bisco
    51,154
    i would do the same. wait until tomorrow, cooler heads prevail. worst that happens is you take the battery back for a new one. not fun i know, especially on a holiday weekend.
    maybe it will fire right up, and not be a problem.
  18. Erin Riel
    28
    Massachusetts
    Just the battery?
    Also thank you very much for helping! Hopefully I'll have good news to share in the morning
    Raytheeagle and scona like this.
  19. bisco
    51,154
    not sure what you mean, what else besides the battery?
  20. Erin Riel
    28
    Massachusetts
    I mean to ask I wouldn't have to tow the vehicle? Just have a trusted car-knowledgeable friend remove the battery and exchange at Toyota?
