Leg panel 12V cigarette outlet replacement
Discussion in 'Gen 2 Prius Accessories & Modifications' started by msg7086, Oct 10, 2024.
  1. msg7086
    msg7086 Member
    39
    38
    North Jersey
    Hi folks!
    The 12V outlet at the passenger leg part is not working well, so I'm thinking about removing it and replacing it with a USB outlet or an FM transmitter. Now I'm facing the problem that I can't take the original outlet out. I was able to remove the air vent piece above and the storage compartment to the right, but I'm stuck here and don't know what to do to disassemble the outlet socket.
    Couldn't find any video tutorial as well. Any help is much appreciated.
  2. msg7086
    msg7086 Member
    39
    38
    North Jersey
    OK looks like it's a universal cigarette socket. I was able to pry the tabs and pull the metal and plastic parts out.
  3. ChapmanF
    17,172
    In my gen 3, I tried unsuccessfully several times to get at the outlet that's in the small forward panel under the flying center console. All the pictures I could find looked like the panel should just pull out, but nothing I tried ever seemed to work.
    The problem was never solved until one night when I'd managed to get a plugged-in power cord wrapped around my ankle while driving, then parked and got out of the car. That pulled the panel out. :D
  4. Has Raf
    Has Raf Member
    180
    42
    Stoke-on-Trent, England
    Do UK gen 2s have this 12V outlet too? I’ve only seen the one inside the armrest cubby.
  5. dolj
    dolj Senior Member
    8,178
    4,166
    Wellington, New Zealand
    No, they don't. AFAIK, most other regions do not have it either.
    Has Raf likes this.
