Less than $3 Nylon alloy center wheel caps in black, white or silver...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Mike500, Mar 24, 2014.
  1. Mike500
    Mike500 Senior Member
    2,593
    764
    There is a long running thread on using metal electrical knock out plugs for center wheel caps.
    Forget the metal ones. Here is a listing of silver, white and black nylon heat resistant ones that are even better, don't corrode with steel on aluminum, and the color is molded in throughout.
    No painting needed for the silver or black ones...
    GRAINGER APPROVED VENDOR Knockout Plug,Hole D 2 In,PK 10 - Hole Plugs - 1EMR6|1EMR6 - Grainger Industrial Supply
    GRAINGER APPROVED VENDOR Hole Plug,Hole D 2 In,Wh,PK 25 - Hole Plugs - 1ELY3|1ELY3 - Grainger Industrial Supply
    GRAINGER APPROVED VENDOR Hole Plug,Hole D 2 In,Blk,PK 25 - Hole Plugs - 1ELY2|1ELY2 - Grainger Industrial Supply
    If you don't have a Grainger account, you can go to any Lowe's Pro Special Order Counter and have them shipped to you home for FREE.
