Lesson Learned - Never blend off a little bad fuel into good fuel
Discussion in 'Fred's House of Pancakes' started by wjtracy, Nov 18, 2015.
  1. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    Many times on Prius Chat I have recommended not mixing a little unknown fuel (or anything else) with good fuel (or any thing else). Unfort I violated my rule when my daughter took a new flat and the prior owner left behind an old gaso container. I do not like the fire safety so I took it home for discard and put a small amount in my lawn mower, being careful to inspect for water. Nonetheless my mower pooped out shortly thereafter, and although I was in denial, I emptied the gaso tank into a clear plastic container I use for spot gaso testing and - sure enough - the fuel was cloudy (not clear) and a water/ethanol layer was readily apparent.
    I had to search on Google for how to recover from water in mower, and they said change out gaso, oil, and carbuetor bowl. Who knew the carb had a little tuna can bowl? But anyways it also had some water layer in it too. Now a week later I am back in business mulching leaves on the ground.
  2. Trollbait
    12,352
    If it isn't a large ratio of water to gas, just add 91% rubbing alcohol or acetone to the gas until the water mixes back in. Ethanol will also work, but why waste it there.;) I'll also add the IPA(not the beer) or acetone to the equipment's tank at the beginning of the season in case water separated out in the carb over the winter.
  3. wjtracy
    11,361
    3,606
    Northern VA (NoVA)
    Yes makes me wonder if hard starting issues of past years is the same issue.
  4. Trollbait
    12,352
    It likely is water or other things coming out of solution, which the IPA and acetone will likely clean up too. Even if you run the tool dry before storing for winter, there will still be some gas left in the carb bowl to leave some gunk behind.
    wjtracy likes this.
  5. davidc83
    davidc83 Member
    113
    50
    Scottsburg, Indiana
    2015 Prius c
    One word: Seafoam. Seafoam is a gas additive (any auto parts store and wallyworld has it) and removes water of gas and it stabilizes gas for up to 3 years and can turn 'bad' gas into useable gas-much more effective than stp or any other gas stabilizer-Seafoam will also clean the gunk out of the lines, carburetor, fuel injectors. I would never use isopropyl (rubbing), alcohol, or methanol in gas-such alcohols erode the rubber parts (gas lines, seals) in small engines, such as lawn mowers, chain saws, leaf blowers, etc... even 10% ethanol (most gas we buy at gas stations) have been know to damage the rubber components. I store a motorcycle in Florida (live in Indiana) and it is not started from 2-6 months. Only thing I do to store it is add seafoam to a full tank of gas-has started every time for 5 years now. All carbureted small engines have a small bowl at the bottom of the carburetor-some have a small screw at the bottom which can be used to completely drain the carburetor. You can add Seafoam to gasoline, diesel, kerosene and add it to engine oil, transmission fluid cases to remove any water which may have developed over time due to condensation.
    wjtracy likes this.
  6. Trollbait
    12,352
    wjtracy likes this.
  7. wjtracy
    11,361
    3,606
    Northern VA (NoVA)
    I'll have to do some blending experiments when I get some time. I am having trouble seeing how a little rubbing alky can take away a layer of water. I still have my mower gaso tank drainings with the water layer. It was highly stinky though...I am concluding my local Shell may have stinky gaso.
  8. Trollbait
    12,352
    Phase separation of alcohol/gas blends happens when there is more water than what the alcohol can dissolve into the gasoline. When it occurs, the alcohol also comes out with the water. So the layer you are seeing isn't just water. Adding more alcohol lets the water and alcohol to mix back into the gas. At blend E30 and higher, phase separation isn't a concern.
    If you want to make pure isopropanol from the rubbing alcohol, add salt. A unique property of isopropanol is that it doesn't mix with aqueous salt solutions. Add enough salt, and it basically draws the water out of the alcohol into a layer.
    If it takes a lot of alcohol to get the layer back into the solution, I'd mix it with a can of fresh gas, and maybe put it in a car's tank.
    wjtracy likes this.
  9. wjtracy
    11,361
    3,606
    Northern VA (NoVA)
    200 Proof rubbing alcohol...
