Lessons learned plugging a tire
Discussion in 'Fred's House of Pancakes' started by bwilson4web, Feb 24, 2019.
Do you have or used a plug kit?
Poll closed Mar 10, 2019.
  1. No - no spare
    0 vote(s)
    0.0%
  2. Yes - no spare
    8 vote(s)
    53.3%
  3. Full size spare
    7 vote(s)
    46.7%
  4. Donut spare
    4 vote(s)
    26.7%
  5. Thanks for the warning!
    1 vote(s)
    6.7%
Multiple votes are allowed.
  1. bwilson4web
    16,012
    After visiting a hardware store, a flat:
    The offender is in the upper left corner.
    Some sort of sheet metal screw based upon the head:
    Using a flat, get it high enough to grasp the head:
    Needle nose, vice grips make it easy to unscrew:
    More easily than trying to remove with the flat screw driver:
    Here is the little bugger. The flat head allows it to rest in the parking lot, pointy end up:
    Unfortunately, no space to work on the repair. So a handy biological (pine needle) went in the tire so the car could back up enough to work on it. I probably should have just backed up with the original object to make it easier to take out:
    So here is the plug in the 'needle' tool to insert. The infernal needle tool:
    Covered in adhesive, it made an impressive wad and would not go in the tire. I briefly thought of backing up over the tool to force it in ... but came up with another approach.
    I had 'rasped' the hole larger but decided to try a flat screw driver:
    It appears to have worked. The wide-side of the flat screw driver avoids clumping up the plug at the entrance of the hole. I am thinking about getting a similar flat and grinding it in about 1-2 mm with very narrow shoulders. The wider surface area will avoid the clumping.
    So I put a plastic bag over the external, patch wadding, and backed over it:
    Now to go test it.
    Robert Holt and Mendel Leisk like this.
  2. Mendel Leisk
    40,582
    Removing the tire, straddling it and using your full weight to push the needle through helps. (y)
    For that bunched up bit, slice it flush with a razor blade or similar.
    Looks like the tires are getting pretty worn anyway, maybe time to start reviewing replacement tires.
    Robert Holt, padroo and Raytheeagle like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    You don’t have “yes and a spare” as an option:p.
    I also have an air compressor as well;).
    Scout motto: Be Prepared (y).
  4. Mark57
    2,945
    2,738
    OK
    Both of my flat kits come with a tin of silicone grease to dip the plug into just before inserting it into the hole. It makes it MUCH easier and does not interfere with the vulcanization seal. They both also come with a knife to trim off the lump on the outside.
    Safety seal
    Boulder Tools tire repair kit.
    I've sealed close to 30 holes in the last 18 years or so with these with not one issue. On road and off road tires.
  5. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    That tire isn't inspectable.
    Those plugs are temporary on a good tire, good enough to get to a vulcanization job, on a tire that's moot?
  6. bwilson4web
    16,012
    I already have a replacement tire but was waiting for nicer weather. The wear bars are getting close but not there, yet.
    Testing revealed a slight bump but it fits within normal Alabama paving practices. But I am thinking a razor knife would trim it down.
    jerrymildred and Mendel Leisk like this.
  7. PA Prius
    PA Prius Active Member
    763
    251
    SE Pennsylvania
    I don't view them as temporary. I've needed to do 3 plugs in the last 18 months. All are holding up well. I was thinking temporary too, but then had our first flat on the Alaskan Highway. I stopped at the next tire repair place a few hours down the road and he said he wouldn't recommend we do anything and that plugs are fine as is. I wasn't expecting that sales talk, but he sold me and we've been good since then. No, the next two flats were not with the same hole or tire!
  8. El Dobro
    El Dobro A Member
    7,075
    3,258
    I keep a kit in each car.
    Raytheeagle likes this.
  9. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,353
    2,347
    Taylors, SC
    I found out the bad news about plugs at my local Discount Tire.
    They consider a plugged tire a liability, since water and other elements can corrode the steel belts and cause unseen internal damage.
    They won't demount the tire and do a permanent internal repair.
    Just be warned.
  10. padroo
    padroo Senior Member
    2,763
    2,251
    I have always plugged my tires since the 1970 and never had a problem. If you want to be totally correct the tire should be replaced and not repaired.
  11. Trollbait
    12,351
    That sounds more like they just wanted to sell you a new tire.
    If these sticky plugs and glue are sealing up the tire to hold in the air, they are coating and sealing up any exposed belt material.
  12. Georgina Rudkus
    3,353
    2,347
    Taylors, SC
    Yeah, just like they won't service any tire over 10 years old.
    I will not risk my life on a couple hundred dollars.
    To me that's a potential L.E.E. "Translate that to be a life ending event."
    Why bother with plugs. Discount Tire demounts, repairs and rebalances tires for FREE.
  13. Trollbait
    12,351
    Rubber ages. Tires generally are only good for 6 to 7 years. Spares might go 10.
    Your other post said they won't demount the tire and repair it.
    Or is that just tires with a temporary plug in them? That seems to be a silly thing to be picky about, seeing how the internal repair is a combo plug and patch made of the same materials as the emergency plugs. Many cars don't come with spares now. Does Discount Tires have the same policy for the slime as the plugs?
    The internal plug and patch is a better fix, but the local shops I went to for a repair just used the outside plug.
    Prius Maximus likes this.
  14. Salamander_King
    Salamander_King Senior Member
    11,009
    8,935
    New England
    That tread looks low. Maybe it was time to buy new tires anyway? I have a flat plug kit with my PRIME, but have never had a chance to use it yet. I also carry a full size spare in my PRIME, but I have not had a chance to use it either.
  15. Mendel Leisk
    40,582
    The first time I plugged a tire was on our 2010, about 18 months in. There was a small finishing nail, a little shy of one inch from edge of tread, causing a slow leak. When the wheel/tire was off the car (snow tires on) I brought it into dealership service department, asked if they would repair, but they refused, saying too close to edge for a "kosher" inside/outside style plug, that the disc on the inside would be riding up onto the curve.
    I can see that, but it leaves me in a bind. I got a quality old-school plug repair kit, the kind that's outside only, watched a few videos, and plugged it. Refilled with just a floor-style bicycle pump. That tire (the OEM) finally is getting replaced, with the rest of the set. Last fall I deemed them "aged out", replaced them while the snow tires were on.
    Never any problems with that repair. Ditto for another plug repair, on one of our snow tires, within the next 12 months: this time a small bolt; the tire went flat very fast. Again, less than inch from edge of tread (so presumably pro-repair again out of the question). Anyway, it was freezing cold, in a parking lot, so I put on the spare, drove home, took the flat in the house, plug repair, bicycle pump. That tire is on the car right now.
    #15 Mendel Leisk, Feb 25, 2019
    padroo likes this.
  16. padroo
    2,763
    2,251
    They always say stay away from the edge of the tire where it starts to meet the sidewall. I think they only want plugs in the steel belted area.
  17. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    I carry a plug repair kit, 12-volt air compressor, Slime, and a full-sized spare retrofitted into the spare tire well on our 2012. I plugged tires on several cars over the years and did not have problems, BUT was told by a tire shop that on stell-belted radials the edges of steel belts around the plug will gradually chew into it and weaken the repair, FWIW. (To clarify, I used the cord-type push in from the outside style of tire plugs.)
  18. Mendel Leisk
    40,582
    I think with the inside style plugs you need to be further from tread edge, due to the larger diameter disc on the inside. I wouldn't doubt they're technichally superior, the inside disc pressing/sealing. Stll, old school, the cord pushed in from the outside, maybe you can get closer to that edge. Again, just my thought.
  19. Trollbait
    12,351
    Sidewall sees more flex that can cause a repair to fail.
    jerrymildred and Prius Maximus like this.
  20. Trollbait
    12,351
    Seemed to have a leak coming from an old plug repair. I just put in a new plug.
