Level 1 vs level 2 charging: efficiency vs battery lifespan
Discussion in 'Gen 5 Prime Charging' started by Chimera1978, Feb 19, 2024.
  1. Chimera1978
    Chimera1978 Junior Member
    45
    San Diego
    2023 Prius Prime
    XSE Premium
    I am trying to figure out if it is better to charge on level 1 or level 2 both from an efficiency perspective and from a battery lifespan perspective. I seem to see that it is more efficient to charge on level 2, which makes sense: if it is the same current due a shorter period of time size it is charging at at a higher voltage, there would be less loss due to resistance in the wires, therefore more efficient. However, I also know that charging at level 2 is more stressful on the batteries and degrade the lifespan of the batteries themselves, but how much? Would it significantly reduce the useful life of the batteries, that is make it sooner before they won't hold a good charge? Maybe since there is a 10 year warranty on the batteries and I can get them replaced before the warranty expires, maybe I shouldn't worry about it on the original battery pack...?
  2. Tideland Prius
    16,612
    Significantly? No. At L2, you’re charging at… 3.3kW? 3.5kW? The battery size is 13.6kWh? 3.5/13.6 is approximately 0.25. So you’re charging at 0.25C. Anything less than 1C is fine. C being charge rate and not coulomb. 1C is the power equivalent to the size of the battery. (In the case of the Gen 5 Prime, that’ll be 13.6kW).
    If anything, L1 could wear out the wires more given that you’re running current through it for longer periods.
    With a PHEV, specifically a Toyota PHEV, I wouldn’t worry too much. Toyota is a conservative company and they’ll take great pains to ensure their products last (see the slow charging on the bZ4X).
  3. RandyPete
    RandyPete Active Member
    409
    169
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    How do you 'wear out the wires'. What does that even mean ?
  4. Mr.Vanvandenburg
    1,358
    588
    2020 Prius Prime
    The level 2 has more current flowing through the wires but bigger wires in level 2 evse. Toyota says the included charging device has a lifespan. That’s a plus for the level 2 because the car device isn’t used. Other people here know more and say the level2 may degrade the pack faster.
    I bet Toyota won’t replace your pack at ten years so you get another new pack. From what others have said, they aren’t that generous. You will have reduced capacity maybe. I think the owners manual talks about it. Like you have half the capacity but the car functions perfectly the same except range on ev.
    I rarely use my full ev range only if going on a trip. I can do fine with half. That’s the beauty of a plug in hybrid.
  5. Louis19
    Louis19 Active Member
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Yes indeed , how sweet it is !:)
  6. NullDev
    NullDev Member
    121
    63
    Ohio
    2024 Prius Prime
    XSE
    The most likely thing to fail in the external charger are the electrolytic caps due to heat. They all have a limited lifespan that is dependent on their temperature. The electrolyte is a liquid/gel that evaporates and degrades faster as it warms up. For instance, it may be rated for 3000 hours @ 100C. Typically, each 10C drop in temperature will double it's lifespan (so running at 90C will last 6000 hours in this example).
    If they designed the charger properly, it shouldn't get that warm inside. Unfortunately, size and material costs usually win out over lifespan.
