Level 2 charging with OEM cord ?
Discussion in 'Prime Plug-in Charging' started by Wiliki, Dec 16, 2019.
  1. Wiliki
    Wiliki New Member
    Colorado
    2020 Prius Prime
    Does anyone know if the OEM charging cord can be used with a plug adapter to have a Level 2 charger ?
  2. Tideland Prius
    16,609
    Rob43 likes this.
  3. Wiliki
    Wiliki New Member
    Colorado
    2020 Prius Prime
    Thanks, I'll check my 'brick' and see if it is rated 120/240.
  4. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Hi
    I'm the thread starter of the above link. Yes is the answer to your question: I build Very high quality 240v adapters for forum members all the time, let me know if you want one.
    Using the Primes 120v Charger at 240 Volts, Cost $20 !!! | Page 9 | PriusChat
    Rob43
  5. Wiliki
    Wiliki New Member
    Colorado
    2020 Prius Prime
    Thanks Rob, I'm pondering how to manage cords in my garage, for when I charge inside or outside the garage. The 120v outlet is close but the 240v is farther away. I might install a 240v receptacle in the ceiling but having a cord dangle is another issue.
  6. Matt1984
    Matt1984 Member
    36
    32
    San Diego
    2020 Prius Prime
    Yes, you can, and you should definitely get one from Rob!
    Rob43 likes this.
  7. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    My 240v outlet is in a similar poor location, in the back of my garage. I built a 25 foot long 10 AWG Pure Copper adapter, it terminates right at the garage door on the inside. All of the parts used are Very High quality, so the electrical loss on my Ohms meter shows virtually nothing. My Toyota OE EVSE connects at that point & simply runs under my garage door. I of course made a slight adjustment to my garage door so that it can't interfere with the Toyota OE cord. This works great for me, it can work great for you too...
    Rob43
    PS, Toyota only makes one Prius Prime EVSE that's used worldwide for all voltages.
  8. fuzzy1
    10,602
    If I recall correctly:
    (*) You won't see 240V listed on your North American label, so you'll just have to take it on faith from the 'anonymous' members here that it has the same internals as supplied in countries with 220-240V;
    (*) Don't simply cut off the plug and replace with a 240V plug, this will lose an essential temperature sensor and brick your brick;
    (*) You can build an adapter yourself, but if your electrical-mechanical skills or readily available parts are not the best, one member here is very well practiced at making them for fellow members.
    Raytheeagle and Rob43 like this.
