Level 2 or Level 3 Chargers for Prius Prime 2018
Discussion in 'Prime Plug-in Charging' started by FMEv, Apr 16, 2018.
  1. FMEv
    FMEv New Member
    2018 Prius Prime
    I bought Toyota Prius Prime 2018 Hybrid Advanced recently and have few questions.
    1. Are level 3 chargers supported by Prius Prime 2018? If yes are there cost effective Level 3 (DC Fast Charging) chargers for home use?
    2. What are few good Level-2 chargers for home? I found few but don't know which one to go with.
    • clippercreek
    • amazon - EV-Gear-Level-Charger-Portable/dp/B074VP6Y2D/
    • chargepoint
    3. What Prius Prime 2018 battery and charging specs I need to pass on to the electrician to install the 240 V outlet?
    4. Any recommendations around twin cities Minnesota? What is the typical cost of work?
    Thanks
  2. Tideland Prius
    16,611
    1. Level 3 DCFC is not available on the Prime. (It's only available in Japan). Also, last I checked, DCFCs are insanely expensive for personal use.
    2. Not sure
    3. 8.8kWh batttery. 3.3kW charging rate at 240V. (8A and 12A charging options)
    07blkprius and FMEv like this.
  3. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    No level three charges:cautious:
    Juice box is really popular. But I don't think you need one as you can usually just charge it up with the included 120v charger
    52,366
    welcome!
    if you want L2, get the cheapest you can find, unless you're looking for bluetooth, record keeping, wifi, phone app, and etc.
  5. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    I know that the spec says 12A, but 12A x 240V = 2.9kW, not 3.3kW.
    3.3kW is consistent with what my power meter shows. 3.577 kW at 239V and 15.01A:
    I'm not sure I could explain the concept of "power factor" for alternating current loads other than to say that the amount of power (in watts) being transmitted may be different than the simple product of volts x amps.
    The bottom line is that a Level-2 EVSE serving your Prime probably should be wired to a 240v circuit rated larger than 15-amps, if only to provide some cushion and prevent the circuit breaker from tripping. Also, because the Prime can present a full load for more than two hours while charging, it's worth noting that circuit breakers do not like to be run a full capacity for extended periods. They tend to get warm and die young.
    A 20-amp circuit should not cost much more than a 15-amp circuit, the only difference being a few pennies per foot for the larger wire size.
    All that being said, if you are installing a new circuit for your EVSE, larger (maybe even 50A or more) is usually better for the purposes of accommodating any future vehicle you may later acquire.
    jerrymildred and Tideland Prius like this.
  6. Tideland Prius
    16,611
    Sorry, you're right. The 8A and 12A were 120V options. Thanks.
    Honestly, I'd wire it for 40 or 50A to future-proof your house. That should cover your EV use down the road (assuming you still plan to live that the same house)
  7. Tideland Prius
    16,611
  8. john1701a
    john1701a Prius Guru
    12,826
    5,306
    58
    We're in the Twin Cities too. Randy's Electric did a fantastic job wiring our garage. We had 2 time-of-use meters installed (Dakota Electric's discount program) along with 2 lines, each 40-amp with NEMA 14-50 outlets, installed by them. That isn't cheap, but well worth it if you want a system to last with a convenient location.
    JuiceBox Pro 40 is what we're using for both of our Primes. That's greater than what Prime can take advantage of. But if you want something to stand the test of time, being able to deliver more years later without upgrade, that's a choice to consider.
    btw, it works great for warming the cabin while still parked in the garage, drawing electricity directly from the wall so you still have full capacity when you leave for work a few minutes later.
    #8 john1701a, Apr 18, 2018
    P.Neophyte and bill188 like this.
  9. P.Neophyte
    P.Neophyte Junior Member
    Fishers, Indiana
    2019 Prius Prime
    Infatuated with your You Tube channel, I've been inspired to purchase 2020 Prime XLE yesterday. Since your post about the JuiceBox Pro 40, do you have any new recommendations for Level 2 chargers, esp. if we want to "future proof"? The technology on this vehicle fascinates me, but it takes real world experience to bring it to life. Keep up the good work.
  10. bisco
    52,366
    i wonder if o/p bailed when she found out there's no level 3 charging capability in prime
  11. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    I'll break this into 3 possible ideas.
    1) If you don't currently have a 240 volt outlet near your Prime, install a NEMA 14-50R or something similar. This will allow for 240v charging up to 40 amps if you ever need it. (which you most likely will)
    2) Buy a high quality $$$ EVSE after you've done your due diligence like a ClipperCreek, JuiceBox, or similar. Do remember that your Prime can only take a maximum of 16 amps, so your charge up time will be slightly under 2 hours.
    3) Buy or build a 240v adapter for less than $50 dollars to save huge money and charge your Prime using your current 120v Toyota OE EVSE unit, your charge up time will take 2:28 minutes. This method allows you to buy the best EVSE/Technology several years from now, when you really need it for your next car purchase.
    Rob43
    #11 Rob43, Mar 27, 2020
    P.Neophyte likes this.
