WTB Level II EVSE
Discussion in 'Private Sales' started by kenmce, Apr 19, 2014.
  1. kenmce
    kenmce High Voltage Member
    1,530
    507
    NY
    Looking for equipment to hook up a PIP to a 240V power source.
  2. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    225
    Harrisburg, PA
    Are you wanting a turnkey solution? To build a L2 EVSE yourself would save money but wouldn't be an instant solution. The PiP doesn't take full advantage of L2 charge rate anyways so IMHO the more cost effective solution is better (DIY) if you're not in a hurry.
  3. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    All of the EVSEs in the UK are 240V, of course. A good number are kicking around, on EBay for example.
    What do you mean that the PiP does not take full advantage of L2?
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Onboard charger of the PiP seems to have a low max output (and thus relatively low input). At work, I've seen PiPs charging @ 208 volts (common voltage for commercial power here) and they seem to pull only ~2.1 kW (so a tad over 10 amps). Even Chevy Volts on those same EVSEs pull ~3.1 kW and '11 - 12 Leafs pull ~3.7 kW.
    My '13 Leaf pulls ~5.8 to 6.0 kW. Most Tesla Model S seem to pull ~6.2 kW (max amperage of EVSEs at my work is 30 amps) but I saw one pull 6.5 kW, somehow.
    The Model S and Rav4 EV have 10 kW on-board chargers standard. Take take full advantage, you'd want a 40 amp EVSE @ 240 volts...
    trentofdestiny likes this.
  5. trentofdestiny
    1,104
    225
    Harrisburg, PA
    I agree with cwerdna. The PiP only uses 12amp max out of the 16amp provided by the smallest retail L2 charger. So an OpenEVSE or a JuiceBox would be about $400 or so. Unless you find someone selling a used L2 station cheaply.
  6. bisco
    49,432
    the important thing to know is that the L2 halves the time that it takes to charge. nothing else really matters to most owners. and yes, the lower the cost the better, unless you're planning for the future. do the euro units operate correctly in the us?
  7. trentofdestiny
    1,104
    225
    Harrisburg, PA
    Depends on where they are designed to be used. US has 240v/60hertz. Some countries have 208, 230, 277 volts and some have 50 hertz. If it's a commercial model it may be rated for all of those.
    If you are building one, your only concern is the power supply (12v DC) to power it all. That's the only thing that runs off the line current, other than the car itself.
  8. kenmce
    1,530
    507
    NY
    Not following here. :confused:
    It will be mounted on a house, so I want to stick to UL listed equipment. Not sure they'd approve DIY. If it was on a pole off by itself somewhere I might be more adventurous.
  9. trentofdestiny
    1,104
    225
    Harrisburg, PA
    It has a small Line to 12VDC power supply to power the electronics and relay. The line current is switched to the car via the relay. There is also a signal wire to tell the car to start charging. It's also controlled by the board in the charge equipment. That is how the EVSE works.
    I would feel the opposite since poles belong to the power company. You can do whatever you'd like inside/outside your own house.
  10. kenmce
    1,530
    507
    NY
    So that's what's going on in there.
    The utility company won't care, it is my homeowners insurance I am concerned about.
  11. trentofdestiny
    1,104
    225
    Harrisburg, PA
    That's understandable. It's like any other kind of home improvement, like building a lamp instead of buying one. Or a computer. The components are mostly all UL listed separately.
