Leviton 240V Charger install video
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 9G-man, Nov 20, 2011.
  1. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    49,399
    it says a thousand bucks for the parts. i thought it was $999. installed?
  3. 9G-man
    1,273
    194
    Atlanta, GA
    The Toyota one is $999 "installed"
    But I guarantee installed means hung on the wall and plugged into an existing socket.
    There is no way that installation will include running a 240v circuit and wall socket.
    That will have to be taken care of separately.
  4. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    Yep
    When I asked about that on the phone with Leviton, the guy on the other end got quiet. Then he said: "We have several installation packages which the installer will select from after looking at your situation".
    This is a case where saving a "buck" only makes sense if you are an electrician or very close to that. Safety is important.
  5. mrbigh
    3,686
    699
    Long Island, NY
    I'm sure it will be other more economic options in the very near future.
    In a little research I made, I just found a USA company manufacturing the EVSE electronic control interface for the EV DIY market.
    modular EV power, LLC
    This is one way to take control of your EV connections expenses
  6. bisco
    49,399
    isn't peef making these things for the leaf?
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    No. He's upgrading the 120 volt Nissan Leaf EVSEs to work at either 120 or 240 volts. See EVSE Upgrade - Products.
  8. mitch672
    mitch672 Technology Geek
    1,077
    197
    Randolph, MA
    "PeeF" here, "Ingineer" on MNL, or just "Phil" if you know him, will certainly be evaluating the EVSE that Toyota ships with the PiP, if it can be safely upgraded to function at 240V, I'm sure he 'll let the forums (Priuschat and MNL) know about it, he modifies the Nissan supplied Panasonic unit for the Leaf for under $300, and it functions at 120 or 240 after he's done. If Toyota also uses a similar design unit from Panasonic, chances are good it can be modified. Checkout his website EVSE Upgrade - Products
    BTW, Home Depot now sells quite a variety of EVSE's as well, I have the Schnieder myself.
    http://www.homedepot.com/Tools-Hard...NT_ID&storeId=10051&catalogId=10053&langId=-1
  9. cwerdna
    12,544
    2,123
    SF Bay Area, CA
  10. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    I find it really annoying from an electronic engineer point of view that these devices are called "Chargers". They are not "Chargers" . The real chargers are onboard the vehicle.
    All these powercube/box devices are are safety switches that pass through AC mains to the vehicle. Basically a GFCI power relay combo switched open or closed on/off by a voltage level and continuity sensor on the control wire coming back from the vehicle. Max current is set by the safety switch device or mains current rating. This value is signaled to the vehicle by a pulse width modulated 1 kilohertz squarewave on the control wire. This squarewave is amplitude/voltage modulated to provide the switch signal mention above.
    Yes I have a copy of the SAE Final standard.
    No switching power supply battery charger functions. No vehicle state of charge functions. Just a "hey we are properly connected OK to close the switch" function.
  11. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Yep. I've mentioned this a bunch of times in my replies at http://priuschat.com/forums/toyota-prius-plug-in/. On MNL they have an EVSE - Charging Equipment subarea with the description "All the discussion about the EV supply equipment (incorrectly referred to as charger by some) go here."
    Since you mention that square wave, that's the pilot signal that I've seen referred to on MNL, right?
