Leviton wants $1800+ to put in EVSE
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by devprius, Mar 2, 2012.
  1. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    I just got back my quote from Leviton for installation of my L2 charger:
    Installation & Unit: $1289
    City of Pacifica Permit: $575
    Total cost: $1864 + S/H & Tax
    Leviton says that to qualify for the $999 basic install, I have to be within 20 feet of the electrical panel. Apparently I'm at 25 feet. An extra $290 for 5 more feet of length. Seems really excessive. They agreed to talk to the contractor to see if they would do it for the $999 basic install price.
    There's not a lot that Leviton can do about the excessive permit fee from the City of Pacifica. I'm gonna try to get a hold of their building department to find out if this is for real.
    The high cost of getting an L2 EVSE installed is leaving a very sour taste in my mouth. So much that I'm not sure if I want to bother. Unfortunately, Leviton already has $100 of my money.
  2. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
    Same thing happened with Aerovironment installing Leaf chargers.
    What many have done is just upgrade the 120V EVSE made by Panasonic that comes with the car, to a 240V L2 capable unit. evseupgrade.com can get it done for under $300, and then you just need a 240V 20A outlet installed, on an L6-20 outlet, any electrician should be able to do it for about $100-$150, or you could do it yourself.
    evseupgrade (PeeF on this forum, Ingineer on the MNL forum), hasn't yet evaluated the L1 EVSE that comes with the PiP, but if you contact them, I'm sure they would be glad to see if it can be done. Once the unit is upgraded, you just get a bunch of short "adapter" cords to fit various outlets, one for the standard 120V, another one for say a dryer outlet, etc.
    checkout the website: EVSE Upgrade - Products
  3. LenP
    LenP Member
    257
    69
    Morris County, NJ
    The 110 volt charge is gentler on the battery and with only a 3-hour charge time why spend the money. Charge it at night and your ready to go.
  4. mitch672
    1,077
    198
    Randolph, MA
    Actually thats not true. The 240V charging is more efficient because there is less "overhead" loss in the onboard charger, and it's only running for 1/2 the time as well. If you are going to spend $999 for a wall mounted L2 EVSE, this option is 1/3 of the price and requires no city permits, and your PiP is fully recharged in 1.5 hours, if you have 240V availble (for quicker turnaround for night trips or at a friends house). The onboard charger is 3.3KW, it's most efficient running it at its designed current and voltage.
  5. daniel
    14,487
    1,519
    Spokane, WA
    When I thought I was going to get the Leaf, Aerovironment wanted $4,700 for my EVSE including installation, and I had a dedicated 240-v. 50-a. circuit right next to where the EVSE would be installed. Your estimate is way less than half of what AV wanted to gouge me for.
    FWIW, I paid Tesla $1,500 for my UMC (Universal Mobile Connector) which plugs directly into my RV-style outlet. The charger has a max output of 240 v., 40 a. There's no permit fee because it's not "installed," and there was no tax because I bought it with the car, and WA exempts EVs from sales tax.
    But $1,500 for the unit alone may give some perspective to your $1,289 before tax and fees.
  6. LenP
    LenP Member
    257
    69
    Morris County, NJ
    I'm just using the 110Volt unit supplied with the car for now. The lower the voltage the less heat generated in the battery pac, but when all is said and done, it comes with the car, no permit needed, and 3 hours is not a bad charge time. If it turns out to be inconvenient then you can always go to the faster 220 Volt install. That's my plan.:)
  7. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I just paid my city $500 for a permit to re-roof my home, but a single electrical outlet, which is all you're doing, would be electrical-only, which is about $125, or (doubtfully) a combination permit, which is about $145.
    You should talk to someone in your City Planning Department. This fee for a single outlet is way too high. There's no way I'd pay it.
  8. planeflyer
    planeflyer Junior Member
    26
    Canby Oregon
    But $1,500 for the unit alone may give some perspective to your $1,289 before tax and fees.[/QUOTE]
    Would one of these units work with the PIP? I also have an RV connection on the wall where the Prius will be parked. If the unit would work on a Prius, how could I get one through Tesla?
  9. mitch672
    1,077
    198
    Randolph, MA
    Planeflyer, Tesla uses its own "standard", so no, you can't use it on any of the J-1772 vehicles.
    See my post on evseupgrade.com above, that would be the lowest cost way to get L2 charging for the PiP, once PeeF/Ingeneer gets a chance to checkout the supplied EVSE
    that comes with the PiP. If it's similar to what Panasonic is supplying with the Leaf, it will be no problem
  10. daniel
    14,487
    1,519
    Spokane, WA
    What Mitch said: Tesla's chargers only work on Tesla's cars. It's even possible that the Roadster's chargers won't work on the Model S.
    And conversely, the Roadster cannot be charged using the J1772 chargers, unless the car has been modified. There is a modification for that, but I've read of problems.
    OTOH, I believe there is a plug-in EVSE for the Leaf, which does not require installation. You just plug it in, like my UMC. I imagine that might work on the PiP, and save you installation charges and permit fees.
  11. Roadburner440
    Roadburner440 Member
    316
    59
    Hampton, VA
    You guys are talking about the Leaf's L1 charge cord. If you go here: EVSE Upgrade - Products he will either modify a unit you buy for $238 to L2, or you can buy one for $1000.. It charges at 240V@16A, but I do not think you really need it for the PiP. I intend on getting the mod done whenever my Leaf gets here as it is easier to install one of those outlets and get the mod done than buy another stand alone L2 charger. Plus you can make adapters to charge at RV parks, and the like. Again it is a lot of money to spend when the 110 will work just fine (for the PiP), but that is my opinion.
  12. mitch672
    1,077
    198
    Randolph, MA
    $999 for a Leviton EVSE is a lot of money to spend to cut the charging time down from 3 hours to 1.5 hours, yet many will still do it.
    Having the EVSE modified that comes with the PiP is likely very possible, because it is a similar unit made by Panasonic that the Leaf uses. My point is, if it can be modified then it's under $300 to get the same L2 240V capability as the Leviton or any other EVSE.
    Also no permit is required, and likely no electrical upgrade either, as the modified unit only needs a 240V 20A circuit with an L6-20R receptacle installed.
  13. devprius
    devprius /dev/geek
    979
    291
    Something I should add is that the EVSE is being hard-mounted outside, so it's not just a simple outlet being installed in my garage. Also, when they run the wiring, it's for a 20A circuit, not a 30A circuit. For $1800, I would expect a 30A capable circuit.
  14. hill
    9,027
    That teeny 3kw of 240v that an L2 runs on is not going to heat the traction pack.
  15. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    It's 6kW @ 240V not 3 kW.
  16. devprius
    devprius /dev/geek
    979
    291
    One of the reasons to install a dedicated L2 charger at home, at least for me, is to make it easier to plugin to charge. I don't have to futz with hauling the L1 charger out of the car when I get home. Or have to put it back in the car when I'm done charging, or I'm ready to leave. I want the L1 to live in the car for when I'm out running around and can charge where there's an available outlet. At home it makes a certain amount of sense to have a dedicated charger. I suppose I could buy a second L1 charger and leave it permanently plugged in, but since I don't park in the garage, but rather in the driveway, I'd have to open the garage door everytime. Having an L2 charger permanently mounted on the outside of the garage makes it a whole lot easier to remember to plugin.
  17. greenleaf
    greenleaf Member
    153
    35
    Silicon Valley, CA
    I believe the charger in the PiP is rated at ~3kW, not 6kW.
    I spent a couple of hours putting in a new dedicated 120V/20A circuit for charging the PiP at L1 yesterday. When the L2 240V/16A EVSE price drops to ~$300 or so, I will probably buy one and then swap out the single-pole breaker for a double-pole breaker (as well as the outlet). This will allow me to charge at 240V using the same wires.
    For me, reducing the charge time by 1.5 hours is not worth the current ~$1k L2 price tag.
  18. greenleaf
    greenleaf Member
    153
    35
    Silicon Valley, CA
    I intend to leave the provided L1 charge hooked up in the garage at home. I will not be bringing it out.
    In my 11 months of driving the Nissan Leaf, I did not even get a single chance to use the provided L1 EVSE during my regular driving. I either charge my Leaf on the public L2 EVSE or with the Blink L2 charger at home. The L1 EVSE just sits in the trunk.
  19. Roadburner440
    316
    59
    Hampton, VA
    The PiP would have a 3.3k charger same as the current Leaf and Volt. So that way you can utilize the 240V@15A. So the charge time for the similar kwh would be the same across all 3 cars.
  20. ryogajyc
    985
    165
    Reseda, CA
    Oops, you are right. I got my numbers mixed up.
