Lexus HS250h at the 2009 Detroit Auto Show
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Paradox, Jan 11, 2009.
  1. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    From Popular Mechanics : http://www.popularmechanics.com/blogs/automotive_news/4298895.html
  2. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    Nice!!!!
    A hybrid-only Lexus model that looks HOT! People will be scrambling for this thing!
    :D
  3. Rybold
    2,760
    322
    Southern California
    The only question now is ... how will BMW and Mercedes respond ? :welcome:
  4. Husker4theSpurs
    Husker4theSpurs Active Member
    656
    127
    Papillion, Nebraska
    Official Lexus Site Info
    Size Comparisons:
    Wheelbase:
    Prius -- 106.3
    HS 250h -- 106.3
    Lexus IS -- 107.5
    Camry Hybrid -- 109.3
    Height:
    Prius -- 67.9
    HS 250h -- 59.3
    Lexus IS -- 70.9
    Camry Hybrid -- 71.7
    Length:
    Prius -- 175.0
    HS 250h -- 184.8
    Lexus IS -- 180.3
    Camry Hybrid -- 189.2
    Width:
    Prius -- 67.9
    HS 250h -- 70.3
    Lexus IS -- 70.9
    This might just be "right-sized" for me personally ... a little wider and a bit longer than the Prius while riding on the same wheelbase. I would imagine EPA estimates a bit above the Camry Hybrid, but not near the Prius ... size increases and tech increases will add to the weight, plus it uses the 2.4L engine ... however it will "heat up" quicker similar to the new RX 450h which helped increase the RX hybrid's fuel economy 8% over the old RX while increasing the engine size.
    I will be interested to check one out personally ... sounds like late summer 2009. One issue is it's not a hatchback ... I would imagine the trunk will be a decent size as they've probably figured out a better place to store the batteries with the new design (stand-alone) over something like the Camry Hybrid.
    I do see it has an ECO/POWER mode ... and EV. Check pics on the Lexus site I linked to confirm.
    I am curious ..... !
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    I don't understand the 250h naming. It has 2.4-liter gas engine but only perform like a 2.5-liter???
    It should be HS330h!
  6. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
  7. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    Looks too much like a corolla and not a Lexus
  8. Rybold
    2,760
    322
    Southern California
    Looking at the vehicle from the rear, I was thinking the same thing.
    I can still see plenty of differences though.
  9. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Typical Lexus. Luxury at any cost. MPG, interior room, etc.
    Ok if that's what you want I guess.
