Lexus HS250h Engine question
Discussion in 'Lexus Hybrids and EVs' started by Bill the Engineer, Nov 27, 2013.
  1. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    Is the 2.4 L engine in the now discontinued hybrid Lexus HS250h just a bored-out Gen III Prius 2.0 L engine? Are they interchangeable?
    Bill the Engineer
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    No. It uses the same engine as the 2007-2010 Camry Hybrid the 2AZ-FXE
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  4. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    I always thought the Prius v would've been better with the 2.5L AZ engine, but apparently, the engineers at Toyota disagreed.
    SCH-I535
  5. Tideland Prius
    16,127
    Possibly weight/packaging issue. I too think it could benefit from the larger engine - more torque, similar FE.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I wish my v had the Gen 3 final gear ratio to get some mileage back, but those same engineers thought a v that slow would not sell well.
    (It will be interesting to see if any actual v owners wanted a bigger engine)
  7. orenji
    orenji Senior Member
    5,884
    3,486
    The Prius engine is pretty much maintenance free compared to a normal gas motor. Is the HS motor the same? Are there no belts to change?
  8. Tideland Prius
    16,127
    No, it is not a beltless engine. It's based on the Gen 1 TCH's hybrid system with the 2AZ-FXE 2.4 litre engine setup.
  9. orenji
    5,884
    3,486
    Thanks for the reply, so are there timing belts on these engines and if so, are they interference free?
  10. Tideland Prius
    16,127
    Interference-free? I don't know what that is. Hopefully someone else can answer that.
  11. orenji
    5,884
    3,486
    If they have a timing belt? and if the timing belt snaps, will engine valves be harmed?
  12. Tideland Prius
    16,127
    I can't remember if it's a belt or a chain, sorry!
  13. orenji
    5,884
    3,486
    I just looked up this engine on line and it seems to be using a roller chain, so it would appear it has no timing belt.
    Tideland Prius likes this.
