Lexus Introduces their 1st BEV Sedan - 2026 Lexus ES 350e and ES 500e
Discussion in 'Lexus Hybrids and EVs' started by drash, Apr 23, 2025.
  1. drash
    drash Senior Member
    2,534
    1,285
    Upstate NY
    New to the Toyota Motor Corporation is the first BEV based sedan from Lexus, the Lexus ES 350e and ES 500e.
    REIMAGINING THE LUXURY SEDAN: THE ALL-NEW 2026 LEXUS ES - Lexus USA Newsroom
    Three powertrains will drive the 2026 ES:
    • ES 350h - 2.5L Hybrid in FWD and AWD platforms
    • ES 350e - FWD based BEV with a manufacturer estimated 300 mile range
    • ES 500e - AWD based BEV
    Wheelbase has been extended about 3 inches (76 mm) over the previous model and length extended by 6.5 inches (165 mm). New dimensions:
    • Length: 202.3 inches (5,138 mm)
    • Width: 75.5 inches (1,918 mm)
    • Height: 61.2 inches (1554 mm) ESh, 61.4 inches ESe (1,560 mm)
    LexusES500e-1.jpg Lexus ES 500e
    LexusES500e-interior.jpg Looks like capacitive touch buttons - ewww.
    No data on battery size or power yet.
  2. drash
    drash Senior Member
    2,534
    1,285
    Upstate NY
    European version of the 2026 ES announcement spills the beans on some estimated stats.
    ALL-NEW LEXUS ES TAKES SEDAN STYLING, LUXURY AND REFINEMENT TO A HIGHER LEVEL
    Powertrain specs:
    • ES 350h: 182 kW (244 hp)
    • ES 350e: 165 kW (221 hp)
    • ES 500e: 252 kW (338 hp)
    Lexus Europe also includes the 300h version (sold in Western European markets) which also was the 2025 hybrid version for the North American market with a little less power than the previous generation ES 300h (215 hp, 160 kW) at 148 kW (198.5 hp). So where does this stand with the Camry and other sedans in the Toyota lineup? Well the new ES sedan is higher than the lifted Toyota Crown sedan by over 1/2 inch (.6 inches, 15 mm). The new ES is also much longer and wider than either the Toyota Crown or Toyota Camry, so if Lexus wanted any differentiation from the Toyota sedans they got it IMHO. Below are comparison pictures for the Toyota Crown and Camry with the new ES 350h.
    ES 350h
    2026 Toyota Crown
    2025 Toyota Camry
    The new ES will start arriving sometime around spring of 2026.
    50,849
    just awful
