Lexus RX400h Custom PIDs
Discussion in 'OBDII Android App' started by usbseawolf2000, May 23, 2012.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,999
    Fort Lee, NJ
    This thread is to kick start the custom PIDs for the Lexus RX 400h hybrid. There is a user with 400h and Torque app setup, willing to test and contribute.
    Perhaps, the best way to start is to use the Prius (GenII) PIDs and report what works and what does not.
  2. vincent1449p
    vincent1449p Active Member
    894
    331
    Singapore
    I do not have any PIDs for RX400h, most likely it has to be built from scratch.
    Firstly, the user need to identify which protocol it is using. By looking at the DLC3 connector, which are the pins have connection. e.g. pin 4, 5, 16, 6, 14 and possibly 7. Since RX400h was introduced after Gen2, I guess CAN must be one of them. Alternatively, user can also use any terminal program and type AT DP to display the protocol detected by ELM327.
    Next, we need to find out the physical address of the ECUs. For CAN, 7E0 is typically for ECM and 7E2 is typically for HV ECU in hybrid.
    After finding the address, we can inquire the ECUs for the PID Map. Using the TEST PID in Torque, send 2100, 2120, 2140,..., 21E0 to get the map.
    With the map, using TEST PID again to send the valid PID to get the response. After this point, it is a challenge to get the correct scaling and offset for the response and it is pretty much guesswork and observations.
    Vincent
    hill likes this.
  3. hill
    8,253
    Vincent, I'm gona guess that your guess is not right :)
    although it was called a 2006 - our 400h was manufactured in 2005 around july. all that to say the 400h was introduced during the early / mid run of the Gen II Prius and not after. The Gen II ran all the way to 2009. It's pretty much the same deal, but for the larger traction pack, and the option of all-wheel drive, which btw our model has.
  4. vincent1449p
    894
    331
    Singapore
    The Gen II was introduced in 2003 model year 2004 and your 400h was introduced 2 years later, that is why I said after. When people talk about what date a car was introduced, they usually refer to their launch date, not the EOL date or the stop production date, no?
    Vincent
  5. hill
    8,253
    I don't know. maybe it's just me. I'd guess that production that overlapped during about 2/3 of of the run, would be considered the same run . . . rather than the next generation's run. That just goes to show you what I know. 1 thing is for certain there are a ton of 400h's out on the road. I see them everyday. They do share the same type of multi function display (resolution) as the gen II prius . . . as well as the dvd map data base and reader. .. and another identical elements.
    SGH-I717R ? 2
  6. SynEco@eVehicle.co.nz
    139
    Hi USBseawolf,
    Was any progress made on getting the RX400H PID data?
    Have an RX400h here if that helps...
    I been using PriiDash and a clone ELM327 but am getting buffer overrun when in ATM logging mode.
    regards,
  7. usbseawolf2000
    14,487
    2,999
    Fort Lee, NJ
    Hi SynEco,
    You'll need Torque app that runs on a Andriod device. Use the Test PID function. Enter the following combo to see if you get any response/reply back.
    Header: 7E0, 7E2
    ModeAndPID: 2100, 2120, 2140, 2160, 2180, 21A0, 21C0, 21E0
    Equation: A
    Example 1
    Header: 7E0
    ModeAndPID: 2100
    Equation: A
    Example 2
    Header: 7E2
    ModeAndPID: 2120
    Equation: A
    You can put whatever you want for the names, min, max and units. Vincent just need the values from the Result.
  8. SynEco@eVehicle.co.nz
    139
    I'm using TorQue Pro with the PRIUS PIDs loaded and most seem to be work the same when connect to RX400h
  9. SynEco@eVehicle.co.nz
    139
    There is also a PID scanner in TorQue but seems to get slower and slower untill it hangs and then termintaes
  10. usbseawolf2000
    14,487
    2,999
    Fort Lee, NJ
    Great to hear. Are you using GenII or GenIII PIDs?
    The PID scanner hangs in Prius the last time I tried also.
  11. SynEco@eVehicle.co.nz
    139
    GenII & USBseaWolfs GenII Metric PIDs ( although some Temp are F not C )
    When i do the PID 2100 Test i notice the response changes periodically ... ( is it normal or a quirk of my clone BT em327 adapter)
    There should be additional PIDs for the AWD mode..
    The 7e3 Battery ECU reports the extra HV modules ( need to add more PIDS for these V and IR of the extras)
    and the higher module voltage reports fine)
    The Rx400/Harrier came out in 2005 so it stands to reason its based on GenII technology enhanced for higher power. Same MFD and Nav also.
    Can EV-Mode be invoked from the CAN Bus ?? or only from hardware EV button ? ( RX400 (2007) did not have the EV-Mode button installed)
  12. SynEco@eVehicle.co.nz
    139
    ID DLC Data Period Count Comment
    020 3 00 00 07 13 82237
    022 8 01 FF 01 FA 00 00 00 25 13 82235
    023 7 02 02 02 05 00 00 35 13 82236
    025 8 00 DF 00 01 78 78 78 75 13 82238
    036 5 1E 00 00 00 59 8 121144
    03C 7 04 00 52 00 10 00 A9 8 121148
    0A2 8 A0 00 00 00 00 20 00 6A 13 82237
    0B0 8 00 00 00 00 11 00 00 C9 13 82237
    0B2 8 00 00 00 00 11 00 00 CB 13 82235
    0B4 8 00 00 00 00 00 00 00 BC 13 82236
    120 8 00 00 00 00 10 20 05 5E 17 60573
    122 5 CC 00 00 00 F4 17 60573
    230 7 00 00 00 01 00 00 3A 25 41118
    244 8 18 88 00 00 00 00 00 EE 25 42139
    262 4 00 05 00 6D 21 49670
    2C6 5 00 00 00 00 CD 34 31265
    320 3 00 00 26 52 20559
    340 7 00 00 00 00 00 00 4A 52 20621
    3CF 5 10 09 19 00 09 142 7568
    420 8 00 01 FF D2 00 00 00 FE 1082 989
    423 1 00 1091 985
    4C1 8 01 00 08 01 00 00 00 00 985 1090
    4C3 8 03 00 06 00 00 00 00 00 1004 1066
    4C6 8 07 00 01 00 00 00 00 00 1040 1035
    4C7 8 08 00 01 00 00 00 00 00 1051 1022
    4C8 8 09 00 08 03 00 00 00 00 1059 1013
    4CD 8 0E 00 01 03 00 00 00 00 1118 960
    4CE 8 0F 00 01 03 00 00 00 00 1125 954
    4D0 8 10 00 20 04 00 00 00 00 1136 946
    520 3 A4 01 6C 1299 127
    521 2 23 00 323 3311
    526 3 24 00 00 540 1984
    527 4 25 01 FA 00 1083 991
    528 4 25 00 00 00 540 1986
    529 7 28 00 00 85 00 00 00 1082 994
    52C 2 23 A9 1083 992
    53F 6 57 01 44 CC 80 60 10830 100
    540 4 25 80 00 00 1082 992
    553 7 58 49 4E 80 00 00 09 10847 100
    554 7 58 57 4B 92 41 58 4D 10848 100
    56A 3 54 30 00 1083 985
    56D 4 65 65 80 7F 1084 993
    57F 7 68 00 10 00 00 00 00 1083 995
    591 5 26 80 20 00 00 326 3292
    5B2 4 25 00 04 00 5408 198
    5B6 4 65 45 00 00 1084 992
    5C8 4 25 00 00 00 1082 998
    5CC 3 24 01 E2 277 3875
    5D4 3 24 00 00 1083 1000
    5EC 7 28 00 00 00 00 98 72 540 1986
    5ED 6 67 08 00 FF 00 00 1061 994
    5F8 2 23 40 1082 993
    5FC 8 69 40 20 00 00 00 00 00 5442 198
    602 2 03 00 55230 17
  13. SynEco@eVehicle.co.nz
    139
    File attached of RX400h CAN pids active
  14. usbseawolf2000
    14,487
    2,999
    Fort Lee, NJ
  15. SynEco@eVehicle.co.nz
    139
    Attached file show the actual responses fro RX400h to PID MAP requests fro 7e0 and 7e2.
    7e3 is not responding to requests but Torque Pro does display 7e3 PID data intermittently
    from the battery ECU ....
    ( These PID maps were traced with CANhacker V2 ( http://www.canhack.de ) using CANusb from Lawicel
  16. vincent1449p
    894
    331
    Singapore
    I think you did not set the Header. By default, Torque will use 7DF if you did not set the Header. 7DF is functional request so any ECUs that are required to response will reply. You get responses from 7E0 and 7E2 that is why it changes when either ECU reply. You need to use physical addressing by changing the Header to 7E0, 7E2 or 7E3. In this mode, only the physically addressed ECU will reply.
    You got responses from Torque because it set the Header before sending the request.
    I've decoded your PID Map and added the supported PIDs in the Comment column. You can use the Testing PID function to get me the responses and I 'll try to compile a list for RX400h.
    Vincent
    robbio and usbseawolf2000 like this.
  17. robbio
    robbio New Member
    marietta, ga
    Hopefully this will not be highjacking too badly. We just got a '06 Highlander Hybrid which I understand is the same platform as the RX400h. I also recently got Torque and am having fun learning how to use it. usbseawolf's GenII PIDs seem to work (haven't checked every one) and I would also like to be able to add the extra battery stuff. So I spent some time in the garage and offer the results here in case they can help. I certainly can't do much more than provide these numbers ;-) File selector wouldn't show me csv that's why these have a txt extension.
    HiHy_Test2_result.txt is the result of logging the Test2.csv file. This returns decimal values (usb's method?) so I just grabbed 1 line for each header. I added lines to test 7E3 but those results appear to be the same as 7E2. However, the raw 7E3 log data was variable for several lines (seconds) before settling into the 7E2 pattern. The lines for 7E0 and 7E2 were completely stable. Not sure if any of that is pertinent, or even if it was done correctly.
    For HiHy_7E2_test_pids_screencap.txt I made a test.csv file of the supported PIDs then used my phone to test each PID and wrote the responses back to the file. I just added enough columns to hold each result (max was 9). The phone is 2.3 so this was screencap the old-fashioned way :) That's why I started with just 7E2 but can do others if necessary. On my setup, Torquescan also was able to find the ones up to 2160, and there was nothing found using the 7E3 header.
    vincent1449p likes this.
  18. SynEco@eVehicle.co.nz
    139
    Puzzles me why can get the Battery ECU PIDs from the RX400h at times but can not see this in the logging hardware ... Could this be because the CRC formula is different and so the packet request and/or responses are being discarded most of the time?
    Definitely Did have the Headers set to the relevant 7E0, 7E2 and 7E3
  19. SynEco@eVehicle.co.nz
    139
    The headers were SET to 7e0, 7e2, 7e3 as appropriate. TEST PID gave no response to 7e3 Headers, Torque real time display occasionally but does Not update regularly as it should and does in the PRIUS )
    Files attached above were from CANhacker log software NOT Torque
    Torque Pro TEST PID get no response if header set 7E3 ( works fine if header set to 7E0 or 7E2 ) but Torque REAL TIME Display does eventually capture the 7E3 PIDs and display the 7E3 data . Also CANhacker see NO 7E3 responses.
    Thanks for the PID maps Will do some more testing ....
  20. SynEco@eVehicle.co.nz
    139
    The key Battery ECU and hv ECU ID codes are unfortunately missing from this list ... these were the codes used for spoofing battery SOC and EV mode in 2004 PRIUS PHEV upgrades , Now not appearing in this scan code list captured from the OBDII connector port.
    Not good news.... more work required for a PHEV upgrade to work
