Li-Ion 12v
Discussion in 'Gen 2 Prius Technical Discussion' started by pbostley, Jul 16, 2014.
  1. pbostley
    pbostley Junior Member
  2. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    A bit more expensive than an Exide or an Optima yellow-top. You'll also have to check out the dimensions as this company uses their own codes for the size/shape factor.
    JeffD
  3. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    Interesting thought. 40Ah seems like overkill though. Here's a 20Ah for $160 that would be kind of interesting to try. Not specifically marketed as a PbA replacement, but voltage ranges and currents look reasonable.
    Elite Power Solutions
    Rob
  4. miscrms
    2,076
    523
    Phoenix, AZ
    There is also a version without the balancers for $124. I wonder how much they would really matter in this application.
    Rob
  5. sneitzert
    sneitzert Junior Member
    We have a 2005 and we used the Optima. We have had really good luck with it and increased our Mpg that had dropped significantly. We used a you tube video to install it and it went really well. We took one of our laptops to the car and follow each step. We now know that the drop in mpg probably the first sign of the battery needing change. We waited until we couldn't start it any more with a jump. Way to long!
