Li-ion and Ni-Cad batteries treated as one?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by davekro, Nov 8, 2013.
  1. davekro
    davekro Member
    480
    67
    SF Bay Area, East Bay
    2013 Prius Plug-in
    This is not new, I am confused again. o_O
    In my initial research on the PIP, there was a lot of talk of the superior Li-ion battery over the regular Prius' Ni-cad battery. During my shopping/tire kicking process I learned the PIP has the exact same Ni-Cad battery under the back seat as the regular Prius, but add a Lithium Ion battery in the space where the spare tire used to be. I was told by salesfolks that the Li-ion battery is what you drove on in EV all battery mode. Now owning and driving my PIP for a week, the car's display screens seem to treat both as one 'traction battery'. In the manual (so far), I have only read reference to the 'traction battery', singular. Is this non reference to two batteries, just for simplification, but the computer (and charge port) treats the batteries independently in it's monitoring of % of charge and charging?
    Do the Ni-Cad batteries get charged too when you plug in? Is the kWh capacity of the Ni-Cads so small that it is not significant at recharge time, or do they usually keep themselves mostly charged from driving around?
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Is the regular Prius nicad or NiMH? If it's Nicad I'm disappointed. :(
    SCH-I535
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    It's Nickel-Metal_Hydryde, the original Prius (sorry, spellcheck couldn't help me with "Hydryde")
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    So far as I know, no car is Ni-Cad, it was mid 80s to mid 90s tech.
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Regular Prius has NiMH.
    PiP has only one big Li-ion battery pack. It is divided into HV and EV portion logically.
    85% to 23% is for EV operation. 23% to 20%? is for HV operation.
    With the use of HV/EV button, you can enter HV mode at any time. The battery state of charge will swing up and down but computer will maintain the % you switched at.
    Astolat likes this.
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    lol, can you imagine the memory problems the Prius or PIP would have with Ni-Cad's?
  7. bisco
    49,490
    salespersons are scary, we should dress up as them on halloween!:eek: pip has one large lithium battery.
    chesleyn likes this.
  8. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    You just always drive electric until the car runs out of juice, then recharge on gas. Enforced pulse and glide, of a sort.
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    that leaves me out because I charge when I have 5 or so miles left EV:cry:
  10. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    Well you do have 2 batteries:
    one small 12v battery (AGM advanced lead-acid battery like regular car but its in the back) and
    one big Li battery in a PiP.
    Maybe that is what the saleman was trying to say (giving him/her benefit of doubt).
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    good point:D
  12. davekro
    davekro Member
    480
    67
    2013 Prius Plug-in
    I am aware of the normal little battery in the rear corner as of course being independent. Are you saying that the PIP's traction battery consist only Li-ion? (finally thinks to go to manual to check specs on battery...) Sun of a gun. Only one listed: Li-ion 3.7 V/cell , 21.5 Ah, 56 cells, 207V. I took that saleman's word as Gospel that under the back seat was the very same Ni-Cad as the regular Prius. Being that he had no bible in his hand, that was clearly my mistake. :LOL:
  13. davekro
    davekro Member
    480
    67
    2013 Prius Plug-in
    My brain was still set in the 80's. I thought nickel and my lizard brain filled in the -cad instead of metal hydryde. my bad. Sorry to dis the Prius cousins! ;)
  14. El Dobro
    El Dobro A Member
    6,979
    3,214
    No Ni-Cads in the Prius, unless there's an old rechargeable flashlight lying about in there. :p
  15. CharlesH
    2,785
    1,152
    Roseville, CA
    The PiP prototype a few years back had separate hybrid and plug-in batteries, but the production models all have just one Li-Ion traction battery (plus the dinky 12v battery). When people run across web pages describing the PiP prototype, they get very confused. Feedback from the prototype users led to Toyota adopting a one-battery approach. In the prototype, the plug-in battery could not accept regeneration.
    The standard Prius has NiMH. As mentioned, NiCd technology is obsolete, and getting rare these days even in small appliances like shavers and electric toothbrushes.
    The distinction between the hybrid and plug-in "battery" is a logical distinction in the software. It's just one physical pack of cells.
  16. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Can you please elaborate on this?
    I am asking as I had this phenomenon yesterday:
    Driving on the highway, I manually switched to HV to preserve EV kms for town driving.
    After about 20 km of highway driving I hit a traffic jam due to an accident with 35 minutes of stand-still to slow crawling, I stayed in HV as I thought my pedal demand will result EV driving (moving) anyway.
    After about 12 minutes or so, the ICE kicked in for about a minute as in warming-up which seemed strange for a warmed-up situation.
    To my surprise, this cycle repeated itself every 6 minutes or so, found it always started at a certain EV km display (in my case 13.1-13.2 km) and ended after adding about 1 km (in my case 14.1 km on the display).
    Conditions: 27 deg C, ECO mode, AC on, flat ground.
    With your comment quoted above I am starting thinking of the following algorithm by the car computers:
    The driver (the loose nut behind the wheel:)) wants to stay in HV for some reason, so let's make his current EV range a target and logically make HV battery portion right there, not letting the range fall below the minimum set.
    I wonder if this is the answer to what I experienced? Or was the ICE kicking in for some another reason (cat converter temp sensor or whatever)?
  17. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yup, your AC was on.:(
  18. Astolat
    Astolat Member
    229
    73
    Guildford UK
    I think I've got it. By George, I've got it!
    Thank you. Should have properly understood this months ago, but that really helped.
  19. markabele
    5,084
    1,782
    Nebraska
    Correct. When you go to HV the computer always wants to get back to the same EV point. So if you go too far below that it will run the engine to get you back up. When you go to HV, just imagine you are driving a regular Prius. When the battery gets too low it has to replenish it somehow.
  20. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    From my observation, PiP allows deeper discharge in HV mode because it can afford it. However, the tolerance threshold gets lower the more charge you borrow and ICE would kick in. Normally, I would accelerate with ICE before a lot of charge gets borrowed. After getting up to speed, the battery charge gets returned.
    In your case, with A/C running, ICE trigger is likely due to charge depletion and reached the trigger point to sustain state of charge.
    An easy way to avoid ICE coming on is of course to stay in EV mode.
    giora likes this.
