License Plate Lights (LED)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dgarcia001, Aug 29, 2020.
  1. dgarcia001
    dgarcia001 New Member
    Miami, FL
    Hey everyone, I recently got pulled over for my license plate lights being out. I had no idea. The next day, I went to my usual auto parts store and kindly asked for the best bulb they had, minutes later they returned with a Sylvania 2825 ZEVO LED pack.
    I was excited that they had LED lights, more powerful, longer lasting, and more efficient. Once i got home I swapped both those pups out and to my surprised, neither bulb turned on... I checked the fuses, the internet, and the manual to no avail. Finally, I decided to look at those awesome LED lights and I realized, the LED's voltage was different from the stores average rated bulb, the Sylvania 2825LL.
    The 2825ZEVOLED needs 12.8V where the OEM ones need 12V. So I went back and swapped them out, and vualá, worked like a charm. But now I have those yellow lights, where I would've preferred the much cleaner looking white LED lights.
    And I'm also left wondering, why?. What's more confusing is that I checked online and the LED's the stores show are 0.5W and the ones I they physically gave me were 1W. o_O
    The Halogens need 12V x 0.417A = 5W
    The LEDs need 12.8V x 0.078A = 1W
    So... I'm not an electrician but, if the LEDs need less Wattage than the Halogens, why is it that the LEDs don't work??
    Thanks
  2. Grit
    Grit Senior Member
    6,139
    4,053
    Wilkes Land
    :ROFLMAO:
  3. JC91006
    16,474
    8,393
    Your original bulbs lasted you 8 years, so the replacements should be very similar. These lights are not for your benefit, they are used to identify you. No need to make it easier with brighter LEDs
  4. fuzzy1
    10,150
    When you tested the LEDs, did you have the car's ignition turned on and READY? Or was the car turned off, or in an accessory mode, with just the lights turned on?
    When the ignition is on and READY, the lights should be fed with 13.5V or more. But when not in READY, the lights will get only the battery voltage, somewhere between the mid-12Vs to high 11Vs.
    So if your original test wasn't in READY mode, consider putting those LEDs back in for another test in READY. If they light up, then good, as all your driving out on the public roads will be in this mode.
  5. Vman455
    Vman455 Senior Member
    534
    551
    The Middle
    The LED bulbs you used are polarity-sensitive; pull them out of their sockets, rotate them 180 degrees and stick them back in.
    Attila Fekete, fuzzy1 and Grit like this.
  6. fuzzy1
    10,150
    I'm seeing conflicting claims on that, on the same product page, as if the design changed sometime along the way and both versions are still present in the marketplace with the same product name and numbers.
    So do try both orientations.
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,148
    2,202
    Taylors, SC
    These are cheap and work everywhere, Replaced nearly all of the "push in" that take this type. All have worked for more than 4 years and are still working.
    dgarcia001 likes this.
  8. dgarcia001
    Miami, FL
    Good point... :confused:
    Yeah, I tried everything and nothing worked. =(
    Yep, I flipped them when I had them and nothing.
    I'll try these out! Thanks for the recommendation!
