Life of an SAE J1772 connector
Discussion in 'Prime Plug-in Charging' started by IABoy987, Sep 23, 2020.
  1. IABoy987
    IABoy987 Member
    184
    76
    Iowa
    2018 Prius Prime
    Stumbled on this interesting 27 minute YouTube video about how and whats inside the fancy Siemens "smart" charger as well as handshaking protocols. Watch and learn what role the small female connectors below the high voltage receptacles in the SAE J1772 connector play, and that unlatch lever did more than you thought.
    (But then you already knew all this, didn't ya? ;))
    #1 IABoy987, Sep 23, 2020
    jerrymildred likes this.
    49,523
    my unlatch lever microswitch lasted 6 years
  3. CharlesH
    2,785
    1,152
    Roseville, CA
    One thing he did not mention in the video about the cost of the EVSE is the royalty fee that has to be paid to the owner of the patent for the J1772 connector. I don't know how much it is, but I understand that it is substantial. The cheap knockoff EVSE's from China don't bother with such niceties as royalty fees.
  4. Old Bear
    Old Bear Senior Member
    712
    1,049
    Boston, Massachusetts USA
    The J1772 connector is engineered to be extremely resistant to damage. The SAE spec provides:
    Receptacle and cord plug
    – Specified to comply with international standards including:
    • J1772™
    • IEC 62196
    • UL 2251
    • Electrical safety
    10,000 cycle life with exposure to dust, salt and water
    Vehicle drive over does not expose a hazard
    – Sealing
    – Corrosion resistance
    – Touch temperature limits
    Also worth noting is that the J1772 standard provides that there is no charging voltage present at the connector until the connector is plugged into the vehicle and the vehicle signals the EVSE that it's ok to energize the cable/plug assembly.
    There is a nice discussion of J1772 in Wikipedia here: SAE J1772 - Wikipedia
  5. bisco
    49,523
    i guess i just got a lemon
    Old Bear likes this.
  6. jerrymildred
    jerrymildred Senior Member
    11,516
    14,120
    Tampa, FL
    I've opened up the handles and those switches are pretty small and delicate looking. I'm not surprised that they fail once in a while.
