Life of the 12V aux battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tickwood, Nov 5, 2007.
  1. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    My early 2004 (Made in 11/03) has the original 12V battery. It seems to work fine, and the car has only 31,000 miles, but I wonder what the life span of the battery is. Does anyone have experience in this area? A close look says I will not do it myself.
  2. ACORNBLUES
    ACORNBLUES New Member
    87
    Its easy :) I'm willing to help a fellow SD prius owner. pm me.
    <div class='quotetop'>QUOTE(Tickwood @ Nov 5 2007, 06:03 PM) [snapback]535124[/snapback]</div>
  3. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Lifespan is going to vary all over the place depending on temps in
    your area, what kind of abuse/deep-discharge it's taken, etc. Don't
    worry about time, just use it till it starts to go [you'll know it!]
    and replace it then.
    _H*
  4. wyounger
    wyounger New Member
    69
    Atlanta, GA USA
    <div class='quotetop'>QUOTE(hobbit @ Nov 5 2007, 11:36 PM) [snapback]535287[/snapback]</div>
    Hehe... my rule of thumb is just the opposite. In my book lead-acid batteries last four years in most applications. If it's not a very important application (the lawn mower) you can just wait until it tells you it wants replacement. If it's going to be a major inconvenience when the car won't start and you have to get a jump every time you stop until you get the battery replaced... you may want to replace it pre-emptively under conditions you get to control, rather than waiting for fate to come along and pick a time for you.
    BTW, if you let fate pick the time, battery chemistry suggests that it will be cold when it happens!
  5. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    rather than make an arbitrary decision, go get the battery tested. the dealer has a device made specifically to test that battery. the battery test will be free if they think they're gonna sell you a battery. and if you need one, they're gonna sell it to ya don't worry. :p
