Life Span of Charging Cable
Discussion in 'Prime Main Forum (2017-2022)' started by Washingtonian, Apr 13, 2018.
  1. Washingtonian
    Washingtonian Senior Member
    716
    617
    While looking in the charging section of the manual to see if the traction battery should be charged or uncharged when parking the car for a month or so I came a section (on page 110) that discusses an error warning when the charging cable is reaching the end of its usable life span. Then another error warning when it has actually reached the end of its usable life span. Of course, there is no mention of what the usable life span is of the charging cable. Will it last as long as the traction battery, or should I think about replacing it a year or two down the road?
  2. PT Guy
    PT Guy Senior Member
    1,085
    710
    Washington, the state
    It isn't just a cable. It is the EVSE electric vehicle supply equipment or charging station, just a portable version.
    My guess is that the pistol shaped connector will be the weak link. It has a moving part...the trigger also activates a switch inside it. In any case, ours is about a year and a half old and showing no signs of deterioration.
  3. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    I used mine for 5 years every night. Worked fine when I sold it. Still works fine a year later.
  4. Elektroingenieur
    2,515
    3,260
    Three Touring
    Toyota’s technical training course for the Prius Prime (see previous thread) says it’s 30,000 charges.
  5. pineprius
    pineprius 15th Hole #4
    245
    134
    NC
    Yep, IIRC the PIP manual stated this as well. 2 charges per day equals 42 years. I'm not concerned. Take care of things and they will last a long time. Abuse, much shorter.
    Oniki and bisco like this.
  6. Trollbait
    11,563
    Receptacles and plugs wear with use, which eventually leads to poor contact for electrical conduction, and that leads to heat.
    But as mentioned, the process takes a long time.
  7. Washingtonian
    716
    617
    That is amazing! I never charge every day, but if I did, in the year 2100 (82 years from now) a message will appear on the dash telling me to contact the dealer about changing the charging cable. Of course, if I add level 2 charging, I won't get that message for 160 years. What a fantastic car!
    benagi likes this.
  8. hill
    8,191
    not the cable - the NOZZLE.
  9. Washingtonian
    716
    617
    I guess that is doable as it appears to be attached with four screws. The owner's manual only discusses "Charging cable life span".
  10. PT Guy
    1,085
    710
    Just the nozzle, the SAE J1772 connector, is listed on fleabay for about $85.
  11. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    Well, if you do replace it think of me when you throw out the origional, I'll pay shipping.
    All agree, the ends will wear from repeated use, in 42years, the cable itself a lot longer.
  12. hill
    8,191
    I have a (short /12-15' ish) spare heavy cable/nozzle, from after installing a longer 25 footer. Probably only been used 850/950 times.
    Does that make me a pakrat?
