Lifetime and Cost for HID Headlamps
Discussion in 'Gen 2 Prius Main Forum' started by mayfieldt, Mar 30, 2005.
  1. mayfieldt
    mayfieldt Junior Member
    Oregon
    I'm really happy that I specified the High Intensity Discharge (HID) headlamps for my new 2005 Prius.
    That was until my so called friend informed me that I will stink up my pants :oops: when it comes time to pay for the replacements.
    Anyone know about how many hours the HID Headlamps are rated for, and the replacement cost?
    I always drive with my headlights on in the daytime, maybe I should reconsider.
    Regardless, I would still specify the HID's.
    My night vision is not what it used to be, :crazyeyes: and these Lamps are soooooo nice.
    Tom M.
  2. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    Tom,
    Conventional wisdom is that the lamp should last the life of the car. I've seen HID lamps rated at 3000 hours. If you figure an average lifetime car speed of 30mph that would be 90,000 miles with the lamps on. I don't know the cost of the bulb, I'm sure it's not cheap!
  3. TucsonPrius
    TucsonPrius Member
    167
    Tucson, AZ
    2020 Prius
    I checked about a year ago, lifetime was indeed something like 3000 hours, cost was around $100 each. And, you should replace them in pairs (the color shifts over time).
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    919
    251
    Surprise, AZ (Phoenix)
    It's also generally a dealer replacement item, so add labor. Reason being is the special handling procedures (gloves must be worn to prevent skin oil residual on the glass which could cause the bulb to burst). There are also special disposal requirements for the old bulbs as they contain mercury vapor.
    I heard sometime in the past a tune of closer to $300.
  5. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    I found the entire headlight assembly (lens, housing, etc.) on a Toyota parts website for $316 each. I can't recall the URL though. Some sponsored link at a site I was viewing advertised discounted Nissan parts, and I replaced "nissan" with "toyota" in the URL and got to the Toyota parts site. It had the entire Prius IC engine listed at about $5700, but no price for the battery.
    If you can dig up the old posting where someone else found the IC engine at a Toyota parts website and posted the URL, it's probably the same site I saw.
  6. KTPhil
    KTPhil Active Member
    1,379
    That $300 price is probably everything except the bulb.
