Liftgate- broken interior handle
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by southtxprius, Jul 22, 2015.
  1. southtxprius
    southtxprius Junior Member
    78
    South TX
    Hello,
    One of the interior handles for the liftgate broke off. I removed it. From what I can tell, this handle is molded to the interior trim part.
    I'd like to glue this piece back on, rather than having to purchase the complete lower trim piece.
    Any suggestions on the best type of glue for this plastic? Thanks! DSCF4407.jpg
  2. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Probably ABS. Get ABS glue from the plumbing section of the Home Store.
  3. southtxprius
    78
    South TX
    It's difficult to see in the photo, but below the RH (right hand side) raised lettering is this: PP/PE. Could this stand for a mix of polypropylene and polyethylene?
  4. southtxprius
    78
    South TX
    Bump. Any other thoughts re: glue for this type of plastic?
  5. bisco
    49,447
    maybe try a simple plastic glue from the hardware store, like model airplane glue.
  6. Mendel Leisk
    38,710
    Test glues? Put a drop somewhere on the inside of the piece, maybe try bonding some scrap plastic to it?
    When you first posted I had to pull out the trim a bit on ours, had a look. Definitely just welded somehow, glue or heat.
  7. southtxprius
    78
    South TX
    I'll give it a shot. Thanks!
  8. Akramahmad1
    Akramahmad1 New Member
    I have the same thing with my 07 Prius the whole lift gate was broken two times until I used loctite super glue then loctite epoxy, the main thing help me prevent the liftgate from being such weak is a handle I used to support, check this video:
