Lifting front of car with jack
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by thomassster, Oct 15, 2021.
  1. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    So the front of the car is really low. Even with my 1.5 ton jack, the height is about 5.25 inches and the car’s panels are about 5”. I can’t roll the jack underneath the car to lift up the front jack point. I know I can lift up the rear jack point easily and use jack stands on the rear which allows enough clearance to fit my jack underneath the front. What are people’s strategy on lifting the front up?
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
  3. vvillovv
    vvillovv Senior Member
    4,336
    1,517
    NY
    If you can't get at that the center front jack point, it's usually easier to safely use the side frame.
    Ya know, the spot where you want to put the jack stand.
    It's not always the best idea to use the lower control arm.
    If ya get that spot wrong or the arm is wet or oily the jack can slip down the arm as you're half way up the suspension travel range.
  4. Mendel Leisk
    42,211
    @jerrymildred fashioned some low-lift timber ramps: two layers of 1.5"x, for a total lift of 3". You drive the front wheels up onto those, then there's enough clearance to roll under most any floor jack.
    And roll you will need to do: the front jack point is 4+ feet back. With that 3" extra lift you should just have enough clearance, to move the jack handle up and down, very limited travel till you get going.
    vvillovv and jerrymildred like this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,558
    2,598
    Taylors, SC
    The answer is a low profile "racing jack: that lowers to three inches.
    vvillovv likes this.
  7. vvillovv
    4,336
    1,517
    NY
    The answer is ........
