Lifting up the rear wiper
Discussion in 'Gen 2 Prius Main Forum' started by Tideland Prius, Oct 31, 2004.
  1. Tideland Prius
    16,621
    Hey...
    I'm trying to find the thread that had instructions on how to remove some plastic in the rear wiper assembly to allow full movement of the rear wiper so that I can lift it up when I clean the rear window. I did a search and couldn't find it (It may have been mentioned in some unrelated topic) Does anyone know how to do so or can lead me to that thread?
    Thanks in advance!
  2. seeh2o
    seeh2o Prius OG
    447
    16
    City of Angels
    I've had the same problem, too, but have never seen it addressed here either!
  3. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i kinda thought that the wiper was designed that way to prevent a stiff breeze from catching it and tearing it off the car.
    because its in the back, it doesnt have the windshield to help stabilize it.
    having one that flips up like the front ones might invite disaster. (although im not sure i would mourn the loss of mine. but i do admit, although it only wiped half the window, it does come in handy here in rainy WA state)
  4. Frank Hudon
    Frank Hudon Senior Member
    4,147
    talk about the rear wiper arm and blade, this is Steve Goldenberg's signature
    White 2004 Prius #9 (BC), Sony T-608/Verizon bluetooth phone, EV kit, mud flaps, window visors, 1 1/4" hitch, leather steering wheel, Mitsubishi rear wiper arm w/20" blade.
    White 2002 Subaru 6 cyl 3.0 Outback LLB
    if you do a search on all his posts he was the only one who was concerend enought to take it on himself to remedy the problem. In his posts he has several about using the Mitzy SUV rear wiper and a new blade to properly sweep the rear window.
  5. Tideland Prius
    16,621
    ok, I went out and fiddled around with it... The area over the rounded part (i.e. the base of the wiper) is just a plastic cover. Just lift it out with your fingers on both sides and wiggle it free. It's attached by a clip and these circular things that just sit in a hole on either side. Removing this cover exposes the nut/bolt if you wish to replace the wiper and it also allows the wiper to be lifted if you're cleaning the rear window.
  6. Tideland Prius
    16,621
    ahh yes, he was the one with the explanation.
  7. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Right, though Steve's complaint wasn't that you couldn't lift the blade but the relatively small area it covered.
    I, too, find it inconvient that it can not be lifted high enough to use a squeege to clean the window. But, I think it is intentional. I'm not sure it can be modified in the OEM assembly
  8. Tideland Prius
    16,621
    See my explanation up there... Sorry if it's not clear. A picture would definitely have helped but yes you can lift it up and away like the front wipers to clean the window. You just need to remove the U-shaped plastic cover at the base
  9. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ok thanks for the info. but to be honest with ya, i just ignore the window for the most part. it seems be stay clean enough. oh course, we get rain on a regular basis, so that might help.
    i have often wondered if the direction of air flow is the reason that the wiper is mounted on top as i feel that a center bottom mount may have provided a much more desired sweep of the glass.
  10. woemcats
    woemcats New Member
    75
    Northern Illinois
    I find that the back window doesn't even get wet enough to use the wiper unless it is raining really hard. One swipe every few minutes seems to do the trick, must have to do with the shape of the car. I do wish the wiper hit more of the window, but it's ok.
  11. Tideland Prius
    16,621
    Yeah it depends. Usually the rain doesn't touch it unless it's heavy or you're stopped at a light. "LO" setting (which really should be INT) seems to have an interval long enough for that purpose
  12. KMO
    KMO Senior Member
    2,011
    734
    Finland
    2023 Prius Prime
    I was cleaning my windows today, and I realised afterwards that I had no problem lifting up my rear wiper, unlike peoples' experiences here.
    The rear wiper on my 2005 UK Prius appears to have a perfectly conventional mount, like the fronts, that pivots up about 70 degrees. No plastic cover.
    So, is the UK version different, or have they changed it for 2005?
  13. Tideland Prius
    16,621
    Do you have an exposed screw at the base of the rear wiper?
  14. KMO
    KMO Senior Member
    2,011
    734
    Finland
    2023 Prius Prime
    Nope, not as far as I can see. It doesn't look like there's a missing cover.
  15. Frank Hudon
    4,147
    can you take a digi picture and post it here so we can see the mount on the motor. If it's different we might have to order from England.
  16. KMO
    KMO Senior Member
    2,011
    734
    Finland
    2023 Prius Prime
    Here are some pictures of my rear wiper. Excuse the low resolution - only have a camera phone to hand.
  17. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Well looky there. Yet another international discrepancy. I'm jealous.
  18. jimofdg
    jimofdg New Member
    533
    DG, IL, US
    Are you sure you're jealous? Though it stands impressively erect, the UK wiper still pivots from the left side of the car. And KMO and others must view it from a right-hand drive position.
    Good thing it doesn't rain much in the UK...
  19. CTScribe
    CTScribe New Member
    Front wiper
    Had my newborn black \'05 out in its first big rain
    Got to see the passenger\'s side wiper base. Is that Darth Vader\'s helmet? They couldn't make this a little smaller?
  20. Tideland Prius
    16,621
    It's needed to swivel the passenger's side wiper due to the unique shape of the window (yes it's still rectangular but rather tall)
