Light Braking: Cruise still on and no taillights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bigdaddy, Oct 24, 2005.
  1. bigdaddy
    bigdaddy Member
    991
    Duluth Georgia
    With the commute now moving into darkness a little more these days, I just noticed that when I *lightly* step on brakes the taillights do not come on. However, I do feel the car braking slightly.
    I've also noticed that when using cruise control, the same amount of braking does not disengage cc, so I am actually in a situation where I am fighting the cc just a little.
    Both circumstances occur when I see a traffic signal in the distance and feel the need to slow down just a tad to time my approach.
    Anyone else experience this? Is there an adjustment I need to the brakes? Warranteed?
  2. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    it does take a bit of pressure to set off the brake lights. it happened in my last car too- you step down very gently and no brake lights. but at a certain point in the range of travel of the pedal, they kick on. it's probably linked to pedal position.
  3. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    How can you tell when the brake lights come on while you are driving?
  4. aka007ii
    aka007ii New Member
    482
    Santa Clarita, CA
    Reflection from tailgaters? ;)
  5. engunneer
    engunneer Member
    307
    Medford, MA
    2020 Prius Prime
    When it's the right darkness out, you can see the reflection off of both back windows in the rear-view. You can also go into test mode and watch the indicator on the screen.
  6. bigdaddy
    bigdaddy Member
    991
    Duluth Georgia
    I can (not) see it in my rear-view mirror while looking at the window (the middle-light). Once I noticed, and then while stopped at a traffic light with slight uphill incline to hold the car in place, I played around with depressing the brake and looking at reflection in the car behind me. None of the the lights come on until a certain point.
    I am concerned about not being able to 'tap' the breaks to get it out of cruise control mode. I am used to doing that, and after tapping the brakes in my prius, the car keeps going.
    Engineer Gunn, how do I get to this test mode?
  7. seasalsa
    1,278
    Kent, WA
    Do you really suggest this alternative? Or do you know an easy way to get the diagnostic screen? Do you really think someone is going to do the following while driving?
    "How to use your screen ( 2005)to get to the differnt screens like the the diagnostics screen that tells you that the car is running ok in each mode.
    One way is to hold the INFO button and turn the lights on and off 3 times. The second method is:
    1) Press INFO
    2) Press DISPLAY
    3) Touch the upper left corner of the area NOT covered by the display function
    4) Touch the lower left corner of the area NOT covered by the display function
    5) Repeat 3 & 4 two more times (a total of 6 pushes).
    You have to power off to get this screen to leave. Pressing the upper left corner of the MFD then the lower left corner of this screen a total of 6 presses (up, down, up, down, up, down), followed by touching the lower right corner brings up more displays. "
    I think NOT!!
  8. tochatihu
    tochatihu Senior Member
    9,549
    3,685
    Kunming Yunnan China
    2001 Prius
    In response to bigdaddy's original question, I would think it very appropriate to have brake lights on and cruise control defeated with only very light brake pedal pressure.
    There is a depth adjustment for the brake light switch - it ought to be quite easy to reset this, even though I am generalizing from my experience with 2001 Prius. I see no reason why Toyota would not adjust that for free.
    I remember reading that a certain group of 2004 Prius had a brake light switch problem, and hope that further details on that would get posted here.
  9. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    brake lights i would think are controlled by a switch attached to brake pedal. it can be adjusted. (at least it is in most cars)
    as for me, since i rarely use the brakes, i dont worry about the brake lights. in fact, when sitting at a light i shift to park so i dont have to burn energy keeping the lights on.
    now dont know if i actually improve my mileage by any measurable amount ( no doubt it helps, but is it measurable??) but it makes me feel better and there is too much in this world to feel bad about, so i embrace the little things in my Prius' life
  10. engunneer
    engunneer Member
    307
    Medford, MA
    2020 Prius Prime
    I suggest it more as a way of learning about how it works (hence "Prius Hacker")
    I wouldn't suggest doing it while driving (though I can do it without looking). The light method is easy to do at a red light (Strange looks from other drivers not withstanding). I also do the NAV override mode while driving, so my wife can use the NAV. It's pretty easy once you know where to hit.
    Also, you don't have to power off the car to leave the mode. You have to hold one of the buttons for a few seconds, then the MFD will reboot. (I thin the INFO button on the MFD, but maybe one of the others)
  11. Frank Hudon
    Frank Hudon Senior Member
    4,147
    as DAS mentioned there was a brake light switch recall on certain 2k4 Prius (wifes car got caught in this one) that had a build up on the contacts in reaction to silicon used in the manufacture of the seat assy. If your's is an early one you should have been contacted by Toyota for a replacement switch. If out of the recall it's possible that the brake light switch just needs adjustment. This should be covered under warranty.
  12. craigcush
    craigcush Member
    157
    Sedona, Az
    I got quite used to my driftwood '05's brake pedal. But after 5000 miles it was totaled and I just got a new Salsa '05 two weeks ago and it is quite different.
    My brakes are applied before the lights AND the regen.
    Coming home from the dealer the brakes were roasting and smelling. There also seemed to be more pedal travel on the first car while this one is touchy.
    So I see there is a threaded adjustment on the brake rod, so there may be more than one fix. (not by me!)
    I have an appointment to fix with the dealer.
  13. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    I can see CC still operating while braking, but regen IS braking. Desired brake force is determined by pedal position and speed of travel. Then the skid ECU decides if it can request regen, or if it must apply hydraulics. Only in fail-safe mode will you operate the hydraulics. Unless in fail-safe mode, you won't have hydraulic brake before regen, unless regen is not appropriate (panic stop, ABS, or speed too slow).
    The brake light switch turns on the brake lights, and turns off CC. There are 2 switches, one NO, other NC. If there's a discrepency, an error is generated.
    In any case, the point where the lights and CC cancel are triggered can and should be adjusted. You don't want it too sensitive either though.
  14. IFixEm
    IFixEm New Member
    69
    a gallon south of Microsoft
    Actually it is a single componant with 2 sides to the switch, thus 4 wires in the connector. The 04's that got new brake switches as part of the ssc, may not have been correctly adjusted. If you remember having the ssc performed, go back. If you are within 3/36 go back. This is a huge saftey issue for the guy following to close to you.
    Regards, Mike
  15. DanMan32
    3,799
    27
    Tampa Bay, FL
    Yes, it is one physical component, but electrically it is 2 switches. One is NO, the other is NC I believe.
  16. Schmika
    Schmika New Member
    1,617
    Xenia, OH
    :lol: :lol: :lol: You need rehab lol
