Light problems
Discussion in 'Gen 2 Prius Main Forum' started by MargeM304, May 18, 2019.
  1. MargeM304
    MargeM304 On the road again...
    Strongsville, Ohio
    Before I head to a dealer or repair shop, I thought I’d ask for advice. I have a 2009 Prius with about 130,000 miles on it. I’m having problems with lights not working intermittently. Tonight I was stopped by a police officer because my rear tail lights were not on. (Front were working). I’ve replaced one headlight, but had trouble with turn signals not working, and the little back lights for my license plate. Before I spend money replacing more lights, I suspect something system-wide in the electronics; I know I need a new 12v battery; I still have the original that has never been replaced. I needed to jump it once this past winter. What should I suggest to the mechanic or be looking for when I go in for repairs? Should I start with the new battery? And although I feel the dealer would know more about the car, I worry they’ll be more expensive than my local repair shop. What’s the best way to start?
  2. kens97uber171
    kens97uber171 Active Member
    177
    132
    US
    Check the 12v battery. When they start to fail.. will cause all sorts of weird system wide issues.
    Battery is in the cargo area back passenger side. Under the carpet.
    Take out removable cargo tray, take out large black center tray, remove little cover on the right side. Battery is under there.
    You can have it load tested at a auto parts store.. usually.
    People on here suggest to stay away from the Optima batteries.
    You want a decent quality AGM battery.
    Probably $150-200.
    So definitely get it tested.
    There is a ground cable back there from battery to the body . Check that and all other connection around there. See if something is loose or corroded.
    Any of that could cause a weird issue.
    Good luck.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,266
    5,963
    Columbia, SC
    Marge,
    I am a strong proponent of fixing the obvious first. If your 12v battery is original to the car, now would be a very good time to change it. Summer heat is just as hard on a battery as the coldest days of winter. At ten years old, it's had a good life, it's time to retire it. It WILL leave you stranded at the most inconvenient time possible. With AAA, you're just losing time, without it, your wallet will be empty about $200 for a tow. Replace it ASAP to eliminate that headache.
    Your other light system symptoms may or may not resolve. License plate bulbs very commonly burn out. They're easy to replace. Many auto parts stores like AutoZone and Advance will install them for free when you purchase the bulbs.
    Once you're confident all the bulbs are good (headlight/signals/brakes/etc), it would be time to evaluate other items if you're still having problems. This could be caused by a multi-function switch going bad. That's the switch on your steering column that operates tun signals and headlights. That is not a common problem, but it does happen.
    #3 TMR-JWAP, May 18, 2019
  4. MargeM304
    Strongsville, Ohio
    Thanks for the ideas guys..... I’ve been meaning to replace the 12v but something always seems to come up first; I’ve been spoiled riding around with my little insurance policy, this charger that works for jumping cars, among other things. Going to try the battery replacement first.
    Skibob and bisco like this.
