Light varnish in '06 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mike Mc, Apr 12, 2012.
  1. Mike Mc
    Mike Mc '16 Prius 4, '13 Prius 3
    88
    35
    Fort Worth
    A few weeks ago I changed the oil pan because someone at the dealership over tightened the drain plug and a few of the threads from the pan were sticking out. When I got the old pan off I noticed the screen was clean but the inside the pan and engine had a thin light brown varnish throughout.
    The car has 170K miles so I suspect a little varnish is to be expected particularly because the dealership did most of the oil changes with dino oil. I have done 3 changes with Mobil1 and Purolator filters. I have not noticed a change (peering through oil fill cap) in the appearance of the varnish. Should I just continue driving and using the synthetic oil and not worry about the varnish or should I try to clean the engine with a little MMO or Auto RX?
  2. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Yes, if it's running alright then that's what I'd do. My personal opinion is that a light varnish doesn't really hurt anything anyway.
  3. Britprius
    Britprius Senior Member
    5,194
    1,917
    Herefordshire England
    I'll second that
  4. wjtracy
    wjtracy Senior Member
    11,329
    3,593
    Northern VA (NoVA)
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,809
    Clearwater, Florida
    Yes dino oil burned in residue. In a motor with that much mileage since you already cleaned the sump filter I would not use any additives.
    Just keep using Mobil 1.
    Btw, you should check the Variable Valve Timing oil filter too with that much mileage. Its a tiny oil filter that filters the oil that drives the VVT timing cam.
    The access port to that filter is located under the intake manifold.
    And requires a hex socket.
    If interested please check my old posts as I have a good write up on it.
  6. Mike Mc
    88
    35
    Fort Worth
    wjtracy- Looking at the mobil 1 pic's the light varnish i was speaking of is more like the after picture...so i guess i'm ok/ thanks all!
    edthefox5- I will have to look for that one...I'm not afraid to turn a wrench so that one sounds like a rainy day repair.
  7. edthefox5
    10,096
    4,809
    Clearwater, Florida
    If you can pull the oil pan the VVT filter will be easy for you.
    Be aware you need a hex on a socket not a key as the hex bolt is in there so tight I needed a breaker bar to get it out. They really socked it down.
