Lightbar installation using fusebox?
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by priusdriver223, Jan 16, 2024.
  1. priusdriver223
    84
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there everyone, I was wondering if it's possible to utilize an empty fuse slot in order to power a lightbar (within the rated amp ofc). Is it as simple as plug and play? Is it safe to utilize an empty fuse slot (interfering with other electronics)? Thanks!
  2. ChapmanF
    18,567
  3. purplePriii
    purplePriii Active Member
    275
    122
    Would the pdf in post 2 help?
    Looking for 2023 Prius Prime Fuse Box Diagram | PriusChat
    I don't see much that could be use to add a circuit but keep the thread posted please, I am also interested in this!
    Not OP but I wanted to say thanks for the link as I discovered my library had a free Chilton access and it has some interesting stuff for the Gen 5. I can't seem to find anything for the fuse box or distribution box with empty slots. Any idea of alternative names? I'm also interested in this project.
    The PDF from the other thread seems a bit more comprehensive but it might not be taken from the same source
  4. priusdriver223
    84
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    I'm going to be testing out all the empty fuses later this week, will update on how this project goes. Thanks guys
    wrtboy168 and purplePriii like this.
  5. ChapmanF
    18,567
    Make sure you're looking in the Electrical Wiring Diagram. That's the EWD tab if you're signed in to TIS; I don't know if things look different the way Chilton arranges it.
    The wiring diagrams have sections on Location and Routing, and also Relay Locations. Relay Locations sections also show the fuses (they're in the same boxes, after all) and will have "Inner Circuit" pages that show what all the interconnections are inside the boxes, and the connector and pin numbers where the circuits come out.
    priusdriver223 likes this.
  6. wrtboy168
    wrtboy168 Member
    70
    28
    Northern California, USA
    2024 Prius
    i got curious after reading this thread. is the light bar mentioned similar to this?
  7. purplePriii
    275
    122
    I am not sure why this guy disconnected his stock third brake light to add this instead of just using both but hey. My understanding on priusdriver223 was for the front as that's where the fuse box is. In the back it'd be easier to add it to the battery next to the mini fuse box for the charger. I might be wrong. I do think the car could use some more light for night driving though so front would make sense.
    Any updates priusdriver223?
    I think what I have access to for diagrams is nowhere close to TIS so I haven't found much. Looking at the manual there might be some heated rear seat fuse that should be empty on my trim but not sure if that's of any use.
    I did find this guy's video and thread who added fog lights to his Rav4 Hybrid which should be somewhat similar:
    https://www.reddit.com/link/11hjsz4/video/51hih5xxz5ib1/player
    There's also this video where the guy has a pretty clean install except that it's straight to the battery:
    #7 purplePriii, Jan 25, 2024
    Bill Norton likes this.
  8. priusdriver223
    84
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    No updates yet since my car is in the body shop, got into a collision due to a truck stopping in middle of the highway at 5am with no lights. Getting it sorted out and then I'm gonna be back on this project.
  9. purplePriii
    275
    122
    That sucks man, I hope it gets fixed well and quickly!
  10. Dyjital
    Dyjital Member
    86
    61
    Oregon
    2023 Prius
    XLE AWD-e
    I too will be installing a setup for a lightbar once I get things squared away with my trailer light situation.
    I did a clean setup in my 22 RAV4 using an additional fuse block that I installed. All main power for light was ran direct from battery and with the Gen5's there is enough plastic body panels under them to run a nice heavy gauge wire from battery to engine compartment to an accessory light bar.
    With my trailer light setup, I'd use the parking lights as the trigger wire for additional/supplemental lighting. Can't post photos here but I have the wire isolated at the rear of the vehicle on the harness. I tend to relay everything to protect my vehicles wiring harness.
    purplePriii likes this.
  11. purplePriii
    275
    122
    Have you ever gotten around to trying this?
  12. priusdriver223
    84
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, yes I have actually and I was actually planning to update this once I have finished up everything but so far, I figured how to wire and mount everything but I have NO IDEA how to get my switch button from my engine bay to the cabin without it daggling outside near my driver door. I wired up my light's positive terminal by literally clipping it to the positive jump starting terminal in the engine fuse box, no screws, no tape, no nothing, just opened up the clip to the jump point and close the clip once i put my light's positive terminal next to it. As for the negative, I untightened one of the nearby bolts on the right side of the engine bay, they're body colored so you know which one it is, and i bolted a relay to another one of those bolts too. And for my mounting, I bought a plate holder that had extra slots for you to mount light accessories, you will usually see those on a jeep, but I basically took off the original front plate mount and bolted my new bracket in and mounted my lights on top of it, once I'm free, I'll share some pictures onto this thread, but so far that's all the work i've done. It would be great if someone can show me where the firewall is that goes through the engine and into the cabin. Cheers!
  13. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    ^^^ Your positive wire connection to the jump point doesn't sound secure and safe at all.
    You risk arcing and sparking, which result in a lot of heat, and therefore risk of fire, or at the very least, melting components under your hood.
    SM-G781V ?
  14. priusdriver223
    84
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, It’s a very tight fit, no room for play at all, the lightbar has a standalone fuse in case of any electrical issues, i know it works because I actually blew the fuse while moving around the switch near my engine bay, been running it for about 3-4 months now and I have checked it every week and no issues, very solid connection. But i understand your concern, cheers!
  15. xliderider
    8,140
    3,277
    Honolulu, HI
    Does your fusebox have any open terminals? In the Gen 3 Prius fusebox, there are two 1/4 inch open terminals that are always hot (+12VDC), so it is like connecting to the 12V battery positive terminal.
    In this picture, there are two red wires connected to the terminals. 120510_1487566341552.jpg
    SM-G781V ?
  16. priusdriver223
    84
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, I guess you can say we have open terminal, it's not exposed so you have to unclip a little plastic cover to access the positive, and I use the body panel bolts as ground. Cheers!
  17. xliderider
    8,140
    3,277
    Honolulu, HI
    Well, I was looking for somewhere to wire the positive wire for a pigtail adapter for an SAE connector to connect a battery charger/maintainer on the Crown Signia we just got.
    There are no open 1/4 inch blade terminals like the Gen 3 Prius fusebox had. But there are several open fuse locations to insert a fuse tap into.
    SM-G781V ?
  18. priusdriver223
    84
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, that’s very interesting, I remember testing empty fuse slots to see if any of them are hot and I didn’t find one, do you know how many amps it could handle? Cheers!
  19. xliderider
    8,140
    3,277
    Honolulu, HI
    I believe that all of the fuses on each side are supplied by a copper bus bar running down one side of the line of fuses. The fuses range from 7.5 amp to 30 amps, so you should be good up to 30 amps?
    When you test the open fuse "slots", you will see that only one side of the slot has a copper conductor, the other side is blank. You will have to install the fuse tap accordingly, put the side away from the side with the wire coming out of the fuse tap into the one with the conductor in it.
    SM-G781V ?
