Lighting strikes 2nd Gen Prius and Driver has video of the event..
Discussion in 'Gen 2 Prius Main Forum' started by Kaptainkid1, Apr 15, 2022.
  1. Kaptainkid1
    Kaptainkid1 Active Member
    308
    247
    Los Angeles
    Check out this video...
    Android ?
    edthefox5 likes this.
  2. RRxing
    RRxing Senior Member
    2,546
    1,822
    NEPA
  3. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    463
    Leawood, KS
    I
    This guy is from Colorado Springs. Good dude. Great drone footage. Lol wow. Lucky.
  4. pasadena_commut
    pasadena_commut Senior Member
    2,643
    788
    Southern California
    What was the path from the body to ground? Hard to tell from the video, but there appear to be some sparks under the car.
    Does the radio still work?
  5. fuzzy1
    10,454
    It could be arcs across the air gap from metal to ground, going around the rubber tires. Lightning certainly has the voltage needed to jump across those few inches.
    For those who missed them, see also:
    Gen 2 versus lightning bolt | PriusChat
    Risky high-speed charger | PriusChat
    #5 fuzzy1, Apr 15, 2022
  6. ChapmanF
    18,215
    Someday somewhere long ago I read that the carbon black in tire rubber compounds made the things more conductive than you might expect.
    Here's a paper about 'green' tires being somewhat less conductive on account of replacing some of the carbon black with other stuff.
  7. pasadena_commut
    2,643
    788
    Southern California
    The current need not have passed through the tires, there is more than enough voltage to cause dielectric breakdown in the air and jump straight from the ground to the car body, but a path through the tires is possible, as the rubber too is beyond its dielectric breakdown limit. The OP should carefully examine the underside of the vehicle, and especially the tires, to check for damage.
    Lightning and Cars
