Lights left on
Discussion in 'Generation 1 Prius Discussion' started by babbles, Jan 25, 2022.
  1. babbles
    babbles Junior Member
    38
    seattle
    2001 Prius
    I notice when you turn off the Gen 1 and leave the headlights in the on position,
    they go out but will that drain any energy by doing that, leaving them on? and too often??
    49,401
    it will put some drain on the 12 volt battery, how long do they stay on?
  3. Trombone
    Trombone Member
    195
    69
    Allentown, Pennsylvania
    2002 Prius
    Short answer, no. I always leave the headlight switch in the "on" position. Lights automatically turn off within 30 seconds after ignition "off."
  4. ChapmanF
    15,509
    Sure it does, the question is, is the amount anything to fuss about?
    The headlights are around 55 watts, if I remember right. There are two. So leaving them on for 30 more seconds after you leave the car drains the battery by an extra 3300 watt-seconds. 3600 watt-seconds would be one watt-hour, so a little bit less than that. One kilowatt-hour, which is a thousand times that, generally costs around a dime, more or less.
    Next time you turn the car on, the battery gets recharged by that amount within the first, again, couple dozen seconds or so.
    WHCSC likes this.
  5. babbles
    38
    seattle
    2001 Prius
    i was going to leave them in the on position overnight but I got nervous about doing it
  6. Mendel Leisk
    38,664
    Yes, of course; car is off, lights are on.
  7. babbles
    38
    seattle
    2001 Prius
    the poster above you says the opposite, thanks!
  8. ChapmanF
    15,509
    Once the car turns the lights automatically off, there isn't any meaningful drain happening just because the switch is in the "on" position.
  9. babbles
    38
    seattle
    2001 Prius
    ok thanks much!
